Tires Narrower tires on 5105m
   / Narrower tires on 5105m #1
Jdmano
Everson, wa
5105m
Some relatives of mine just purchased a 5105m tractor to use in there raspberry fields. To fit down the rows properly we need it narrower than the rear fenders. We installed 9.5-24 goodyear duratorques for front wheels. Jd says to install 14.9-28 on rear. Did that and it dropped the drawbar 6 inches. Which was too much. Talked to salesman and he said we could install 14.9-30 on the rears which would be same rolling circumferance as 16.9- 28 which is a drawbar height we like. Recieved and mounted 14.9-30 tires and it raises the drawbar only 2 inches. And when measured to the 16.9-28 is the inches shorter. Can anyone explain how this works and what size tire will give us the same height as a 16.9-28.
   / Narrower tires on 5105m #2
How narrow do you want to go? I have 12.4R42s on my 5420 and 5310 with 11.2R24s on the front.
   / Narrower tires on 5105m #3
You should be running at least 30-38's on that tractor. Tell your dealer to install the 38 Firestone radials on your tractor.
Id like to stay with a 14.9 width it fits nicely under the fender. How tall is your tires the 14.9-30s were about 53 inches tall and the 16.9-28s were about 57.
   / Narrower tires on 5105m #5
I would say get 15.5R38s or something like 14.9R34/38 but I'm not sure if 14.9R34 or R38 is a common size.
2019 TAKEUCHI TL6R SKID STEER (A51246)
2019 TAKEUCHI TL6R...
1266 (A50490)
1266 (A50490)
2022 FORD F-250 SUPER DUTY (A52472)
2022 FORD F-250...
2012 KENWORTH T600 SERIES (A52472)
2012 KENWORTH T600...
2018 FORD TRANSIT T250 CARGO VAN (A52577)
2018 FORD TRANSIT...
Yale 3,500lb Electric Forklift (A51691)
Yale 3,500lb...
