napa oil filters
   / napa oil filters #21
I have a CK20HST, bought it last July have about 28 hours on it, not real happy with it right now, after an hour or so of use it won't even pull it self. I have changed the trans filter with a NAPA filter found the cross reference on another filter makers web site. NAPA filter was less than $11. On a dealers web site the original filter was over $48. Cut the filters in half see which is better. Think I'll stick to NAPA
   / napa oil filters #22
have you taken this to your dealer? no since in selecting a screen name like yours if you haven't tried to have it fixed... warranty covers problems....
   / napa oil filters #23
How did you get 28hrs if it won't pull itself? Not trying to be sarcastic but you give very little info about what is happening here. Please provide some details and we will gladly try and help.
Steve
   / napa oil filters #24
<font color="blue"> I have changed the trans filter with a NAPA filter found the cross reference on another filter makers web site. ........Cut the filters in half see which is better. Think I'll stick to NAPA </font>
Napa filters are made by Wix, and they are excellent filters, but only if they are right for the application. I have found out the hard way it doesn't pay to blindly trust cross references -- especially from third parties. I suggest getting the OEM filter specs and seeing if the Napa filter meets them in all respects. Do not assume you can go 'tighter' on the specs, either, especially with micron level. You may have pump cavitation as a result.
Added: From your post, I'm guessing you have a hydro. Check and see if there is a pick-up screen in the oil sump. Sounds like it may be clogging.
   / napa oil filters #25
I have talked to the dealer about this problem, they are the ones who suggested changing the filter before I bring it to them, they also didnot have the filter I needed and I certainly was not going to pay $48. plus $9. shipping to order fron another dealer online
   / napa oil filters #26
So have you changed the filter at all??
How far away is your dealer you purchased it from and does he have the filters on order?
   / napa oil filters #27
Re-read your post... it says you have changed the filter?? Did it help? If not have you called your dealer about this?
   / napa oil filters #28
Hello unhappy, sorry to be inqusitive, but where are you from and what dealer did you buy this ck20 from? Their are many trolls who frequent this chat room so its hard not to be skeptical when someone has 28 hours on a new machine and tries to trouble shoot the problem himself, and then comes to a chat room with no backround listed or a profile that bashes the tractor he just bought. There are many dealers here whod be happy to help you with a little more information..
   / napa oil filters #29
This all sound unreal, first if i bought a tractor and had trouble I would take to a Dealer. I can't believe the dealer ask him to change the filter with only 28hr, and Napa do not cross that filter, so if you got napa filter on its problely wrong. I work for Napa 34 years they do not want to use a filter just because it fits
   / napa oil filters #30
seems like everyone has the same thoughts I do..... /forums/images/graemlins/smirk.gif
2016 RAM 5500 Bucket Truck - Cummins Diesel - Auto Trans - 4X4 - Altec AT41M Boom (A55302)
2016 RAM 5500...
2005 Sterling Acterra Tender Truck (A56435)
2005 Sterling...
2020 INTERNATIONAL MV607 REEFER BOX TRUCK (A58214)
2020 INTERNATIONAL...
Quick Attach Bale Spear (A57454)
Quick Attach Bale...
LOT: (200 approx.) Gallons of Chevron Delo TorqForce SAE 10W Hydraulic Oil (A59076)
LOT: (200 approx.)...
LOT: Kimball Midwest 4-Drawer Hardware Cabinet w/Contents & Stand (A59076)
LOT: Kimball...
