napa oil filters
   / napa oil filters #11
</font><font color="blue" class="small">( My local NAPA does have a listing in there NAPA book for Kioti. They were able to look up the NAPA number for my LK. NAPA shows the oil and fuel filters but no air filter. The last time I was in they listed for the LK and DK series don't know about the CK. )</font>
Napa has a listing of the LB, LK, and DK models. They also list the CK 20 (oil filter only) last time I checked.
They show the oil filter ( Napa # 1324) and fuel filter ( Napa # 3507) for my DK 35.
   / napa oil filters #12
"The only difference I see is the NAPA filter is bigger so I guess more capacity for filtering."
This tells me that they have found a filter in their catalog with the same threads. It worries me more that the filters arent exactly the same dimensions, maybe the internals are different too like check valve, filter media, etc.
   / napa oil filters #13
I stick with Kioti filters simply because they are not expensive and they are what the warranty calls for. If you were to have a failure, it could be argued that you did not follow the warranty rules of using Kioti approved filters. However, I doubt you would have a real problem, but it IS a potential.
John
   / napa oil filters #14
<font color="blue"> "If you were to have a failure, it could be argued that you did not follow the warranty rules of using Kioti approved filters. "</font>
I belive it is against the law to void the warranty by not using the manufactures own brand of filters.
See this LINK on the Filter Manufacturers Council tsb web page.
I only know what I read /forums/images/graemlins/confused.gif
   / napa oil filters #15
</font><font color="blue" class="small">( "If you were to have a failure, it could be argued that you did not follow the warranty rules of using Kioti approved filters. "
)</font>
You may very well be right, but since the Kioti filters are not so expensive, I just avoid ever having to find out by using only those filters!!
Thanks for the info.
John
   / napa oil filters #16
The CarQuest (Wix)85182 filter is longer and the removable side cover rests on the end of the filter. It won't take long for the side cover to vibrate a hole in the end of the filter. Now, that certainly isn't worth it
but it does fit
   / napa oil filters #17
"I belive it is against the law to void the warranty by not using the manufactures own brand of filters"
Willman,Thanks for the link,I was looking for something like that to show my Nissan dealer.They saw that I had used a Fram air filter and said they would not cover the mass airflow sensor if it should fail,I said "yeah right" and left.......Mike.
   / napa oil filters #18
O.K. I'm going to bring back an old thread, I did an oil change about 3.5 hrs ago. I used a napa gold 1182 filter. I started it up this morning, and could hear a loud clicking noise above 900 rpm's. I traced it back to the filter, I could feel a pulse on the end of the filter. It felt like someone tapping on the filter from the inside. My guess, I think the inside relief came apart, or something, and the pump was dead heading. I took it off and replaced it with a new Kioti filter and it works great. I'll stick to the Kioti parts from now on. BTW napa's was over $11 Kioti's was $9's don't change your oil on a Sunday with out parts on hand.
   / napa oil filters #19
There is a discussion over in Branson about the same issue.
I think I'd stick with the manufacturers recommendation.
Call your dealer and have them ship your filters if you can't make the trip.
A little extra on shipping is worth the lack of aggravation.
just my opinion
Becky
   / napa oil filters #20
Kioti. Daedong donaldson oil filter #- P550158-- Fram oil filter #-- PH2921 AC delco oil filter #--PF2106--- S T P oil filter—S3985 hope this help you can find these at most
parts houses
Don /forums/images/graemlins/cool.gif
Giyi Pallet Forks (A53314)
Giyi Pallet Forks...
BARBED WIRE (A58214)
JOHN DEERE LAWN MOWER (A55758)
JOHN DEERE LAWN...
2008 INTERNATIONAL WORKSTAR 7400 SBA 6X4 DUMP TRK (A52706)
2008 INTERNATIONAL...
Chevrolet 2500 Flat bed (A56435)
Chevrolet 2500...
Midwestern Industries MEV Screen Model MEV 5X10-2 (A56435)
Midwestern...
