NAPA Fuel filter to replace Kubota......???
   / NAPA Fuel filter to replace Kubota......??? #1
bswiv
Palatka, Fl
CAT D5G, Kubota M8540, KubotaB2700
Is there any reason to spend extra on a Kubota Fuel filter when NAPA has a cross referenced part number for a NAPA filter that is less expensive?
It's only about $10 difference but if the performance is the same........??
   / NAPA Fuel filter to replace Kubota......??? #2
Napa generally has a good reputation with filters, but there is usually no way to be certain that aftermarket filters meets OEM specifications. Messicks Equipment did an interesting YouTube video comparing aftermarket to Kubota filters a while ago. It was not very scientific, but some of the aftermarket filters appeared pretty low quality.
That said, I do use aftermarket oil and fuel filters on all of my engines. I generally stay with OEM filters for hydraulic applications. The aftermarket filters I personally consider to be quality are Napa, Baldwin, Fleetguard (Cummins) and Cat.
Thank you.............
   / NAPA Fuel filter to replace Kubota......??? #5
I may have to knock Napa off my quality filter list.
The video left me wondering too.....especially as I always use the Gold on our D5......and on the transport for it.
   / NAPA Fuel filter to replace Kubota......??? #8
Meanwhile, many many farmers are using NAPA filters, without any problems at all! Me included!
SR
   / NAPA Fuel filter to replace Kubota......??? #9
I saw a video on Kubota's filter and aftermarket and none of them (the ones selected) even came close. I would not exchange a $10 savings vs a mechanical problem.
   / NAPA Fuel filter to replace Kubota......??? #10
Pitts Tri-Axle RGN Lowboy Equipment Trailer (A50322)
Pitts Tri-Axle RGN...
2016 WITZCO RG-35 RGN LOWBOY TRAILER (A50459)
2016 WITZCO RG-35...
2013 PETERBILT 365 T/A DUMP TRUCK (A51406)
2013 PETERBILT 365...
2018 DIAMOND C 40 FOOT GOOSENECK (A53843)
2018 DIAMOND C 40...
Clark 4,000lb Propane Forklift (A51691)
Clark 4,000lb...
2018 MDB LV600 GREEN CLIMBER SLOPE MOWER (A51406)
2018 MDB LV600...
