Name this mystery part!
/ Name this mystery part! #1
Griffey
Bronze Member
Northern Michigan
B7610
I did some work this weekend and then I ended up finding this bolt and rubber piece in my drive way. I am going to start looking through the owners manual, but I thought maybe I'd check to see if anyone recognized the part here. I attached a picture. Any guess to where it came from?
/ Name this mystery part! #3
Check the fenders and cab for a similar type bolt and then go looking for an empty hole. /forums/images/graemlins/grin.gif
Egon
/ Name this mystery part! #4
Egon
/ Name this mystery part! #5
The rubber part appears to be like a vibration damper. If you have cab, I'd look there. Also, maybe radiator mount?????
Good luck.
ron
/ Name this mystery part! #6
Good luck.
ron
/ Name this mystery part! #7
</font><font color="blue" class="small">( Also, maybe radiator mount?????)</font>
That was my first thought.
/ Name this mystery part! #8
/ Name this mystery part! #9
It is a cushion nut and bolt, commonly used by Kubota on sheet metal to metal connections, such as cowlings, hoods, platform, ect.
What did you remove? Sometimes you have to hold them from the back to get them to tighten properly...they are sort of like a compression fitting.
/ Name this mystery part! #10
Nothing was removed. I just found the pieces in my driveway. THey must have worked them self loose.
I'll check the suggestions mentioned above. Keep them coming if you have any other ideas.
2019 UTILITY VS2DX 53' X 102" T/A VAN TRAILER (A59912)
2019 UTILITY VS2DX...
2016 Land Rover Discovery Sport SUV (A61574)
2016 Land Rover...
UNUSED WOLVERINE RSB78-78" ROCK SCREENING BUCKET (A64281)
UNUSED WOLVERINE...
2016 John Deere 6155R (A64119)
2016 John Deere...
2017 Xtreme Telescopic Telehandler (A60352)
2017 Xtreme...
Land Pride RCF2072 6ft. Rotary Brush Cutter Tractor Attachment (A61572)
Land Pride RCF2072...
