NAA Oil Leak
   / NAA Oil Leak #1
OrtisEvans
Laytonsville, MD
Ford NAA, Farnall Cub, Kubota B2100
My NAA drips a small quantity of engine oil - just enough to be annoying. I made a new gasket for the oil plug, and that helped some. I plan to replace the oil pan gasket, which should be pretty easy. Here's the question: I am wondering if I can replace the real seal (two-piece rope type) without splitting the tractor and all that entails. Is it possible slip a new seal in without major disassembly?
On the same tractor, the right brake sticks if it sits for a while. When I start, I have to reverse to release it and even then it sometimes drags a few feet first.
Thanks
   / NAA Oil Leak #2
get a sneaky pete tool for the crank seal.
for the brakes, disassemble and lube linkage and pivots and bushings.
soundguy
   / NAA Oil Leak
Thanks - I had not heard of that tool before. Perfect.
On the brakes: I did disassemble/clean/lube them once, but that was a while ago and I don't recall how thorough I was. I'll do it again. I can't imagine there could be a weird bearing or rear-end problem with these syptoms, especially since it has been going on for years.
Ortis
   / NAA Oil Leak #4
if it's not a binding shaft / bushing causing the brakes to drag, make sure they are not adjusted too tight, and make sure the springs are good and intact.
soundguy
2016 Ford Fusion Sedan (A50324)
2016 Ford Fusion...
2012 VOLVO EC300DL EXCAVATOR (A51406)
2012 VOLVO EC300DL...
HYDRAULIC FLOOR JACK (A53843)
HYDRAULIC FLOOR...
1838 (A51248)
1838 (A51248)
2016 CATERPILLAR 249D SKID STEER (A52705)
2016 CATERPILLAR...
2018 VOLVO VNL DAY CAB (A52576)
2018 VOLVO VNL DAY...
