NAA Oil Leak
   / NAA Oil Leak #1
OrtisEvans
Laytonsville, MD
Ford NAA, Farnall Cub, Kubota B2100
My NAA drips a small quantity of engine oil - just enough to be annoying. I made a new gasket for the oil plug, and that helped some. I plan to replace the oil pan gasket, which should be pretty easy. Here's the question: I am wondering if I can replace the real seal (two-piece rope type) without splitting the tractor and all that entails. Is it possible slip a new seal in without major disassembly?
On the same tractor, the right brake sticks if it sits for a while. When I start, I have to reverse to release it and even then it sometimes drags a few feet first.
Thanks
   / NAA Oil Leak #2
get a sneaky pete tool for the crank seal.
for the brakes, disassemble and lube linkage and pivots and bushings.
soundguy
   / NAA Oil Leak
Thanks - I had not heard of that tool before. Perfect.
On the brakes: I did disassemble/clean/lube them once, but that was a while ago and I don't recall how thorough I was. I'll do it again. I can't imagine there could be a weird bearing or rear-end problem with these syptoms, especially since it has been going on for years.
Ortis
   / NAA Oil Leak #4
if it's not a binding shaft / bushing causing the brakes to drag, make sure they are not adjusted too tight, and make sure the springs are good and intact.
soundguy
BUYERS PREMIUM & PAYMENT TERMS (A54607)
BUYERS PREMIUM &...
2018 KENWORTH T880 DAYCAB (A53843)
2018 KENWORTH T880...
2019 Kenworth T270 Rollback Wrecker (A53117)
2019 Kenworth T270...
6 Pallets of Oil / Chemicals Absorbing Pads (A53117)
6 Pallets of Oil /...
2021 John Deere 333G Compact Track Loader, 390 Hours, High Flow Hydraulics, Ride Control (A53473)
2021 John Deere...
2003 Pierce Tilt Cab Foam Pumper Fire Truck (A54814)
2003 Pierce Tilt...
