Soundguy
Old Timer
- Joined
- Mar 11, 2002
- Messages
- 52,424
- Location
- Central florida
- Tractor
- RK 55HC,ym1700, NH7610S, Ford 8N, 2N, NAA, 660, 850 x2, 541, 950, 941D, 951, 2000, 3000, 4000, 4600, 5000, 740, IH 'C' 'H', CUB, John Deere 'B', allis 'G', case VAC
if you can't find the rebuild kit for the hyd top cover then you simply havn't looked.
it's about 15$ at your CNH dealer. 00 top cover kits are available too.. for about the same price.
gets you the piston oring and washer, top cover gasket, and a cyl gasket and a handfull of orings.
if that was your problem.. .. I hope you didn't rebuild the pump for nothing.. 500$ is 500$
pays to troubleshoot before opening wallet.
DO get a manual BEFORE you pull that top cover.. don't damage the backpressure valve taking the top cover off.. that are not as easy to find as they used to be...
Hey guys, if the lift arms work with no emplament and will only raise some of the distance with and leaks down when engine is shut off then what? I have changed a $500 pump, changed oil and cleaned the screen but no luck. I have a Hinamoto E230 and its being a pain. I am looking for a rebuild kit for the lift piston but haven't had any luck yet. Can you guys let me know if I'm headed in the right direction?
