NAA Hydraulic Trouble Shooting
   / NAA Hydraulic Trouble Shooting #11
if you can't find the rebuild kit for the hyd top cover then you simply havn't looked.
it's about 15$ at your CNH dealer. 00 top cover kits are available too.. for about the same price.
gets you the piston oring and washer, top cover gasket, and a cyl gasket and a handfull of orings.
if that was your problem.. .. I hope you didn't rebuild the pump for nothing.. 500$ is 500$
pays to troubleshoot before opening wallet.
DO get a manual BEFORE you pull that top cover.. don't damage the backpressure valve taking the top cover off.. that are not as easy to find as they used to be...
Hey guys, if the lift arms work with no emplament and will only raise some of the distance with and leaks down when engine is shut off then what? I have changed a $500 pump, changed oil and cleaned the screen but no luck. I have a Hinamoto E230 and its being a pain. I am looking for a rebuild kit for the lift piston but haven't had any luck yet. Can you guys let me know if I'm headed in the right direction?
   / NAA Hydraulic Trouble Shooting #12
What CNH tractor are you saying relates to the Hinamoto E230?
   / NAA Hydraulic Trouble Shooting #13
i don't know of any ford similar to a hinamoto.
you have jumped into the middle of a discussion on a ford NAA tractor / hyds information.
   / NAA Hydraulic Trouble Shooting #14
Peterbiltz71 Try posting your question about your Hinamoto tractor in the Grey Market Tractor section. Hinomotoman or Lens12 can answer your questions
   / NAA Hydraulic Trouble Shooting #15
way bette than tagging on at the end of a post on a totally unrelated tractor, derailing the thread a bit....
PLUS you might actually get the answers you need / help you need from the people that know that machine.
Good luck.
2015 Kubota MX4800 4WD Tractor with LA1065 Loader Backhoe (A55787)
2015 Kubota MX4800...
2018 CATERPILLAR 303.5E2 CR EXCAVATOR (A52705)
2018 CATERPILLAR...
2008 GENIE GTH-1056 TELESCOPIC FORKLIFT (A52705)
2008 GENIE...
1995 Western Star 4900 T/A Wrecker Tow Truck (A55788)
1995 Western Star...
2022 KUBOTA MX5400 HST TRACTOR (A54607)
2022 KUBOTA MX5400...
John Deere Bale Spear (A55218)
John Deere Bale...
