n00b question - what size are the lug nuts/boltson my 2011 DK50se?
   / n00b question - what size are the lug nuts/boltson my 2011 DK50se? #1
MossflowerWoods
Super Member
Fredericksburg, VA
Kioti DK50SE HST w/FEL, Gravely 60" ZTR Mower. Stihl MS290 (selling), CS261, & FS190 + Echo CS400 & 2010 F-350 6.4 PSD snowplow truck
I destroyed a front tire and got a replacement, now I need to get the rim off the tractor, and none of my impact sockets seem the correct size. I also can't drive the tractor closer to the house on 3 wheels, so trial and error is taking too long...
Is it metric (like every other bolt/nut on the tractor) or SAE?
Thanks in advance,
David
   / n00b question - what size are the lug nuts/boltson my 2011 DK50se? #2
Thanks in advance,
David
Have you tried to measure them? Might save some time.
   / n00b question - what size are the lug nuts/boltson my 2011 DK50se? #3
If you need to be at the house, apply down pressure to your fell enough to lift the front end up and move in reverse to the house?
Sorry, I already drove too far on it...
:D
David
   / n00b question - what size are the lug nuts/boltson my 2011 DK50se? #6
if you have portable air compressor just mount tire where its at
   / n00b question - what size are the lug nuts/boltson my 2011 DK50se? #7
Or, literally pull yourself up by your bootstraps...
Nylon tow strap around axle, over the loader arm and back. Lift the loader and make a slow retreat in reverse towards home (and a tool box). It's a tippy ride but it works.
   / n00b question - what size are the lug nuts/boltson my 2011 DK50se? #8
Thanks in advance,
David
They are metric.
   / n00b question - what size are the lug nuts/boltson my 2011 DK50se? #9
Its a 24mm socket.
Its a 24mm socket.
God Bless you Murph!
My 15/16 was close, and I did not want to round them off.
Biggest I have is a 22mm, so I will go pick up a 24mm today.
THANK YOU!
Be well,
David
JOHN DEERE 5403 TRACTOR (A57192)
JOHN DEERE 5403...
KUBOTA BX2350 TRACTOR (A57192)
KUBOTA BX2350...
2019 Ram 1500 Classic 4x4 Crew Cab Pickup Truck (A55852)
2019 Ram 1500...
2018 Ford Fusion Sedan (A55853)
2018 Ford Fusion...
55 GALLON DRUM DOLY (A57192)
55 GALLON DRUM...
MARATHON 25KW GENERATOR (A58214)
MARATHON 25KW...
