n00b question - what size are the lug nuts/boltson my 2011 DK50se?
   / n00b question - what size are the lug nuts/boltson my 2011 DK50se? #1
MossflowerWoods
Super Member
Fredericksburg, VA
Kioti DK50SE HST w/FEL, Gravely 60" ZTR Mower. Stihl MS290 (selling), CS261, & FS190 + Echo CS400 & 2010 F-350 6.4 PSD snowplow truck
I destroyed a front tire and got a replacement, now I need to get the rim off the tractor, and none of my impact sockets seem the correct size. I also can't drive the tractor closer to the house on 3 wheels, so trial and error is taking too long...
Is it metric (like every other bolt/nut on the tractor) or SAE?
Thanks in advance,
David
   / n00b question - what size are the lug nuts/boltson my 2011 DK50se? #2
Thanks in advance,
David
Have you tried to measure them? Might save some time.
   / n00b question - what size are the lug nuts/boltson my 2011 DK50se? #3
If you need to be at the house, apply down pressure to your fell enough to lift the front end up and move in reverse to the house?
Sorry, I already drove too far on it...
:D
David
   / n00b question - what size are the lug nuts/boltson my 2011 DK50se? #6
if you have portable air compressor just mount tire where its at
   / n00b question - what size are the lug nuts/boltson my 2011 DK50se? #7
Or, literally pull yourself up by your bootstraps...
Nylon tow strap around axle, over the loader arm and back. Lift the loader and make a slow retreat in reverse towards home (and a tool box). It's a tippy ride but it works.
   / n00b question - what size are the lug nuts/boltson my 2011 DK50se? #8
Thanks in advance,
David
They are metric.
   / n00b question - what size are the lug nuts/boltson my 2011 DK50se? #9
Its a 24mm socket.
Its a 24mm socket.
God Bless you Murph!
My 15/16 was close, and I did not want to round them off.
Biggest I have is a 22mm, so I will go pick up a 24mm today.
THANK YOU!
Be well,
David
UNUSED WOLVERINE MPF-11 2500G 30" PALLET FORKS (A57193)
UNUSED WOLVERINE...
2017 Ford Explorer AWD SUV (A55853)
2017 Ford Explorer...
2003 Big Tex 10PI...
(15) 1 RANCH 1RGPM GROUND PROTECTION MATS (A57193)
(15) 1 RANCH 1RGPM...
LINCOLN ELECTRIC IDEALERARC DC-600 WELDER (A57192)
LINCOLN ELECTRIC...
2007 Gulf Stream Canyon Trail 33FBHT 35ft. T/A 5th Wheel Travel Trailer (A55853)
2007 Gulf Stream...
