Mystery Post Hole Auger
   / Mystery Post Hole Auger #1
harwill
Dallas, Texas
Hew Holland TC40A
Anybody know what brand this is? The casting on the gear case says "J and S foundry, Dewey OK" and of course there is no such listing. Just trying to decide whether to overhaul or toss. Thanks.
   / Mystery Post Hole Auger #2
Can't resist... looks like a green one!
mark
   / Mystery Post Hole Auger #3
If you can not fix it, you might consider replacing the gear head with a hydraulic motor, and let you tractor hydraulics do the work.
   / Mystery Post Hole Auger #4
   / Mystery Post Hole Auger #5
I have a old central Tractor PHD that the main shaft in it broke . It cost me $200 to have a shaft made. A new PHD was about $350 I figured that I had all the other parts for it why throw away everything so I had the shaft made and put back together , well 7 years later still using it. V
mark
Yeah, that's part of the mystery! Really, there's a Yaller one underneath the Green! Gotcha! Are we having fun yet?
   / Mystery Post Hole Auger #7
Have ya priced a new PHD lately??
If it's in decent shape then rebuild it.
   / Mystery Post Hole Auger #8
I have a Vassar PHD, that is made in Oklahoma (not sure where). It has ears on the gearbox similar to yours. But maybe all of them do.
Hope this helps.
ron
Hope this helps.
ron
Thanks. I'll see what I can find. The ears are the hang point for the pin that goes thru the lift arm.
   / Mystery Post Hole Auger #10
Hi there mystery solved I have one also it is a Five Star Mark III I need parts also , the cutting edge bolt on flaps or what ever they are called . I am also looking for a copy of the owners manual . If anyone can help I would greatly appreciate it . thanks Kirk:thumbsup:
2010 THOMPSON TRASH PUMP (A51406)
2010 THOMPSON...
2025 SDLANCH SDLE18P UNUSED Mini Excavator (A53117)
2025 SDLANCH...
ITEM LOCATION LOT IDENTIFIER 3 (A53084)
ITEM LOCATION LOT...
2001 HAULMARK ELITE II 8' X 24' CARGO TRAILER (A51247)
2001 HAULMARK...
2025 IR UNUSED Hydraulic Breaker (A53117)
2025 IR UNUSED...
