Mystery Post Hole Auger
   / Mystery Post Hole Auger #1
harwill
Dallas, Texas
Hew Holland TC40A
Anybody know what brand this is? The casting on the gear case says "J and S foundry, Dewey OK" and of course there is no such listing. Just trying to decide whether to overhaul or toss. Thanks.
   / Mystery Post Hole Auger #2
Can't resist... looks like a green one!
mark
   / Mystery Post Hole Auger #3
If you can not fix it, you might consider replacing the gear head with a hydraulic motor, and let you tractor hydraulics do the work.
   / Mystery Post Hole Auger #4
   / Mystery Post Hole Auger #5
I have a old central Tractor PHD that the main shaft in it broke . It cost me $200 to have a shaft made. A new PHD was about $350 I figured that I had all the other parts for it why throw away everything so I had the shaft made and put back together , well 7 years later still using it. V
mark
Yeah, that's part of the mystery! Really, there's a Yaller one underneath the Green! Gotcha! Are we having fun yet?
   / Mystery Post Hole Auger #7
Have ya priced a new PHD lately??
If it's in decent shape then rebuild it.
   / Mystery Post Hole Auger #8
I have a Vassar PHD, that is made in Oklahoma (not sure where). It has ears on the gearbox similar to yours. But maybe all of them do.
Hope this helps.
ron
Hope this helps.
ron
Thanks. I'll see what I can find. The ears are the hang point for the pin that goes thru the lift arm.
   / Mystery Post Hole Auger #10
Hi there mystery solved I have one also it is a Five Star Mark III I need parts also , the cutting edge bolt on flaps or what ever they are called . I am also looking for a copy of the owners manual . If anyone can help I would greatly appreciate it . thanks Kirk:thumbsup:
BESTWAY AG LOT NUMBER 53 (A53084)
BESTWAY AG LOT...
Vermeer D16X20A Directional Drill with Mixing System and Trailer (A51573)
Vermeer D16X20A...
2013 UTILITY VS2RA 53FT REEFER TRAILER (A52141)
2013 UTILITY VS2RA...
1275 (A50490)
1275 (A50490)
2015 John Deere 8245R MFWD Tractor (A53342)
2015 John Deere...
2005 Ford Focus Sedan (A51694)
2005 Ford Focus...
