Mystery part near fuel bleeder valve
   / Mystery part near fuel bleeder valve #1
SDAnnette
San Diego
Case D45
Hello,
I was changing my fuel filter when I mistakenly(late, wrong glasses...) unscrewed this part in the picture. It looks like it has nothing to do with the fuel, but holds something in place.
If someone can identify how this needs to be re-installed, I would feel a lot better. I found the threads and screwed it in, but the flange with 2 holes on it is currently not holding anything I can see in place?
This is on a Case D45, I would look at the schematics, but now they don't let you see my machine from 2006.
Thanks in advance for trying to help,
Annette
   / Mystery part near fuel bleeder valve #2
If I’m looking at your arrow correctly it appears to be a screw type hose clamp. It looks like you can see the indents in the hose. It needs to be slid a little to the right and tightened up.
   / Mystery part near fuel bleeder valve #3
The plate with the 2 holes needs to go on the 2 lower hooks. The bolt needs to then push up on the upper loop, but something seems to be missing like a nut or something. The easier solution might be to just remove it (or just loosen it a little and slide it down the hose and leave it there) and install s typical hose clamp in it’s place.
   / Mystery part near fuel bleeder valve #4
Guess I'm late to the topic. Orezok's response is absolutely correct.
Thank you for the pictures and solution!
I was so frustrated. I have another "mystery part" I will ask the forum with a picture. It fell off my tractor years ago, but I can't figure out from where. I think it is a guide of some kind. You guys are excellent!
BTW, my dad was stationed at EAFB for years.
4"x8' Treated Post, 36 Piece Bundle (A52384)
4"x8' Treated...
1994 GMC SIERRA C3500 DUALLY TRUCK (A51247)
1994 GMC SIERRA...
2019 TAKEUCHI TB290 EXCAVATOR (A51246)
2019 TAKEUCHI...
2019 Dodge Challenger GT AWD Coupe (A51694)
2019 Dodge...
(2) 330 GALLON POLY TOTES (A51248)
(2) 330 GALLON...
UNUSED FUTURE FT36CJ STAND ON SKID STEER (A51247)
UNUSED FUTURE...
