Mystery Dust Cap Found On The Ground While Mowing...what did this come from?
   / Mystery Dust Cap Found On The Ground While Mowing...what did this come from? #1
AGTtactical
Kubota SVL95; Kubota L6060HST
Was out yesterday mowing with my new L6060, and new Land Pride FM2572 flail mower. Tractor and mower are awesome, and I've been using them both pretty hard. After mowing, wife found this cap lying on the ground. Any idea what this came from? Neither my mechanic at our Kubota dealership, nor Landpride have any idea. I didn't see anything obvious... didn't look really hard though because I figure some smart guy here will know right away. And, I was also mulching in the same area last year with a Kubota SVL-95, but I doubt it came from that. Thanks guys!
   / Mystery Dust Cap Found On The Ground While Mowing...what did this come from? #2
It's not a plug for one side of your front loader mount is it? My loader doesn't have plugs but the size looks about right.
Good question! Where is the mount? Sorry, never had a loader on a tractor...and I don't see it. Here's a pic. Tractor Side View.jpg.
   / Mystery Dust Cap Found On The Ground While Mowing...what did this come from? #4
That looks like a smaller version of the plug on my Landpride 4’ rotary cutter (bush hog).
   / Mystery Dust Cap Found On The Ground While Mowing...what did this come from? #6
Don't know about your Kubota, but my NH1920 has a rubber stopper like that on the rear of the center hydraulics casing, right behind the seat, that I pour the hydraulic fluid in.
Ok...I'll look there too. Thank you.
   / Mystery Dust Cap Found On The Ground While Mowing...what did this come from? #8
That does look like a plug for hole on the bell-housing. Usually used as an inspection hole for tractors with clutch. Probably not your case since yours is HST.
I would still check the bottom of the bell-housing. Manufacturers will put a hole there to also inspect the 4WD coupling in case the roll pin breaks or something.
   / Mystery Dust Cap Found On The Ground While Mowing...what did this come from? #9
Landpride finish mowers have caps similar to that on the holes covering the lube points for the deck or where the belt pulleys are. Might look around n the Landpride flail mower for a hole that such a plug fits.
   / Mystery Dust Cap Found On The Ground While Mowing...what did this come from? #10
Look on the land-pride rotary cutter deck directly behind the gear box. If a plug like the one you found is there, you have an extra. If a hole is there, see if the plug fits.
MAHINDRA MAX 24 HST COMPACT UTILITY TRACTOR WITH LOADER (A52748)
MAHINDRA MAX 24...
2013 MACK ELITE LEU 633 GARBAGE TRUCK (A51406)
2013 MACK ELITE...
2013 Chevrolet Impala Sedan (A51694)
2013 Chevrolet...
2013 PHOENIX GLOBAL TANDEM AXLE MANIFOLD TRAILER (A52472)
2013 PHOENIX...
JOHN DEERE HPX GATOR 4x4 *NOT RUNNING* (A50324)
JOHN DEERE HPX...
1998 WELD-IT COMPANY FUEL TRANSPORT PUP TRAILER (A52472)
1998 WELD-IT...
