Mysterious Connector
/ Mysterious Connector #1
RoadmasterD
Oregon
Kubota L3560HST-LE
Hello,
I noticed a mysterious connector in the cab of my new tractor. The tractor is an L3560LE and the connector is on the left side of the cab near the bottom of the left window (see pic). Anyone know what it is for?
/ Mysterious Connector #2
Hello,
Worklights, or optional heated glass?
Aaron Z
/ Mysterious Connector #3
It's for the worklight. The fuse is on the fuse panel below and to the left of the steering wheel. I think it's ten amps.
/ Mysterious Connector #5
/ Mysterious Connector #6
On mine that is just keyed power. I tested it and it was not switched, key on = power on, key off = power off. Saw somewhere that it was and auxiliary power.
I will put a multi meter on mine later today and check it out. Thanks for all of the feedback.
/ Mysterious Connector #9
I think that is for a heated rear window or wiper;on a cab Kubota the work light(rear) are (out-side)wired under the caution lights.I hooked mine up and bought the switch from Kubota.
/ Mysterious Connector #10
I would agree. My L4060 has the same plug; my tractor has front and rear work lights plus front and rear wipers. However, mine does not have heated rear glass.
How's you Limited Edition treating you?
I have not had an opportunity to get it dirty yet but I will be out on our property this weekend and doing some mowing and loader work. Thanks for asking.
Case IH 315 Magnum (A62177)
Case IH 315 Magnum...
2021 Gehl RT215 Track Loader with 74in Smooth Bucket (A63689)
2021 Gehl RT215...
17in. Tooth Excavator Bucket (A64194)
17in. Tooth...
2014 GULF STREAM TRAILMASTER (A65643)
2014 GULF STREAM...
2013 Honda Pilot AWD SUV (A61574)
2013 Honda Pilot...
2016 Ford F-150 Crew Cab Pickup Truck (A59228)
2016 Ford F-150...
