Mysterious Connector
/ Mysterious Connector #1
RoadmasterD
Oregon
Kubota L3560HST-LE
Hello,
I noticed a mysterious connector in the cab of my new tractor. The tractor is an L3560LE and the connector is on the left side of the cab near the bottom of the left window (see pic). Anyone know what it is for?
/ Mysterious Connector #2
Hello,
Worklights, or optional heated glass?
Aaron Z
/ Mysterious Connector #3
It's for the worklight. The fuse is on the fuse panel below and to the left of the steering wheel. I think it's ten amps.
/ Mysterious Connector #5
/ Mysterious Connector #6
On mine that is just keyed power. I tested it and it was not switched, key on = power on, key off = power off. Saw somewhere that it was and auxiliary power.
I will put a multi meter on mine later today and check it out. Thanks for all of the feedback.
/ Mysterious Connector #9
I think that is for a heated rear window or wiper;on a cab Kubota the work light(rear) are (out-side)wired under the caution lights.I hooked mine up and bought the switch from Kubota.
/ Mysterious Connector #10
I would agree. My L4060 has the same plug; my tractor has front and rear work lights plus front and rear wipers. However, mine does not have heated rear glass.
How's you Limited Edition treating you?
I have not had an opportunity to get it dirty yet but I will be out on our property this weekend and doing some mowing and loader work. Thanks for asking.
John Deere 612 2-Bottom Plow (A63116)
John Deere 612...
2005 JLG Skytrack 10054 10K Capacity Telehandler (A59213)
2005 JLG Skytrack...
KUBOTA BX23SLB-R-1 TRACTOR (A62129)
KUBOTA BX23SLB-R-1...
2013 Volvo VN Semi (A64047)
2013 Volvo VN Semi...
2001 LEXUS RX300 SUV (A62130)
2001 LEXUS RX300...
UNUSED CFG INDUSTRIAL H15R MINI EXCAVATOR (A62130)
UNUSED CFG...
