The majority of those "break in contaminates" occurred within the first few hours of use over a full temperature range (cold - hot) and loading (light - heavy).Mahana79 said:interesting report on my first oil change. i know i did it past the 50 hr mark but i think it was still relatively low hrs at 110. What are yalls thoughts??
ihookem said:I changed mine after 23 hrs. It was very dark. Mine takes 3 qts. Very cheap insurance. Then at 90 hrs. I changed again. My oil seems to get black fast an it seems strage to not change it when it looks like that.
I don't understand your comment. Could you please explain what you mean?RoyJackson said:...BTW, you should have waited until after your manual call out for break in hours. Too late now, of course, but if you experience some oil usage, that may have been the cause.
RoyJackson said:My oil is still straw colored (like new) after 75 hours...but I've seen a lot of diesels looking black within a few hours of an oil change.
Nothing to worry about, IMHO.
Offering that advice as a blanket statement is neither completely accurate or responsible. Much depends on whether or not you should change the oil earlier than the first scheduled oil change, including ring material and/or whether or not the factory oil is "break-in" oil with additional anti-wear additives in it (nowadays more than likely to be the case). There indeed have been cases where rings failed to seat properly and increased oil consumption resulted for many hours/miles before they eventually did, as well as robbing some "service life" from the engine due to increased component wear. People - swallow your pride, trust that the folks who designed and built your engine know better than you, and follow their instructions. It never fails to amaze me how many people think they're going to "get one over" on the manufacturer by short-changing the break-in cycle.Skyco said:Don't worry about early oil changes when new, I've done that on every motor I've ever owned and consider it very inexpensive insurance, it will not hurt your ring break-in. Some debate the use of synthetics too early can harm ring break-in, I'm not so sure since many high end cars come from the factory with synthetic in them from the assembly line.
3) He mixed up his motor oil and SUDT bottles.john_bud said:There are 2 reasons for the oil in Roy's tractor being still straw clear. (aside from bad eyes, Skyco!)
1) the engine is equipped with a high performance 0.5 to 1 micron bypass filtration system.
2) the tractor is not worked hard enough to produce any soot.
Those are the only ones I am familiar with. Anyone know of a third reason?
jb
DiezNutz said:Offering that advice as a blanket statement is neither completely accurate or responsible. Much depends on whether or not you should change the oil earlier than the first scheduled oil change, including ring material and/or whether or not the factory oil is "break-in" oil with additional anti-wear additives in it (nowadays more than likely to be the case). There indeed have been cases where rings failed to seat properly and increased oil consumption resulted for many hours/miles before they eventually did, as well as robbing some "service life" from the engine due to increased component wear. People - swallow your pride, trust that the folks who designed and built your engine know better than you, and follow their instructions. It never fails to amaze me how many people think they're going to "get one over" on the manufacturer by short-changing the break-in cycle.
I'd love to hear that you work for Kubota and know for a fact that they don't? See, I don't know beyond a shadow of a doubt whether Kubota does or doesn't, nor do I claim to, nor do I even care since (a) I followed their advice, and (b) 50 hrs didn't take long at all to rack up. But I certainly don't go around telling people to thumb their nose at whatever the manufacturer suggests. No, break-in oil isn't a thing of the past... Honda/Acura, VW/Audi, and reportedly Benz use a special break-in oil or additives (VW in their TDI diesels as well), to name a few, and it's even right in Honda owner's manual. Couldn't tell you exactly what it is, but my guess is it's at least non-detergent. Additives don't have to eliminate ALL wear...MoS2 for instance helps cut down on a good bit of bearing and cam/lifter wear, while still allowing the rings to seat (which there's a good chance they're moly-faced at least anyway) and even cutting down on some of the ring shear.Skyco said:I'd love to hear of ANY manufacturer that uses a verified "break-in" oil. That is a thing of the past. Also please explain how a so-called break-in oil could contain additional "anti-wear additives". That is completely counter intuitive since break-in implies there IS wear to seat parts.
DieselPower, if I may quote you from 3/22/07 "Best Break In for Diesel", in response to Redbug's question about break-in oil:DieselPower said:There is nothing wrong with changing your "break in" oil sooner than called for. The majority of break in happens within the first couple minutes of operation. The only thing that tends to take a little longer to break in is the rings and cylinder walls. Operate the engine at moderate and steady RPM's for the first few hours with light to medium load and they will seat in just fine.
As for the original fill being a actual "break in" oil it is highly unlikely. Very few engine manufacturers use break in oil anymore. In fact I can't actually think of any. As far as I know Caterpillar, Cummins, Detroit Diesel, Wackashaw, International to name a few use a standard off the shelf oil as the factory fill.
Naturally I have to ask, since I find it hard to believe that so much has changed across the manufacturing landscape in the past 5 months, why the apparent 180?DieselPower said:Actually it has a massive amount of ZDDP (zinc) in it. During break in there is even more need for EP anti-wear additives. Break in oils usually have anywhere from 2 to 5+ times the additive package compared to regular oil.
My procedure is to do the first change at 5 hours. This is when the majority of the initial break in occurs and changing it removes all the metal contamination. I then change the oil and refill with a regular dino oil and add 2 bottles of EOS. EOS can be purchased at any local GM/Chevrolet dealership and is a engine assembly oil that is mainly just a base oil carrier with a very large ZDDP additive package, basically I am making my own break in oil. I then run this oil change to the 50 hour mark and from then on go with my regular extended drain intervals with UOA's.
