My Thoughts On Modern Day Tractors
   / My Thoughts On Modern Day Tractors #11
Kubota MX5200​
Kubota MX5200 tractor photo
2014 -
Utility tractor
Kubota MX5200 Weight:
4WD shuttle: 3,716 lbs
1685 kg
4WD hydro :3734 lbs
1693 kg
Kubota MX5200 Power
Engine (gross):54.7 hp
40.8 kW
Engine (net):52.1 hp
38.9 kW
Shuttle PTO (claimed):45.7 hp
34.1 kW
Hydro PTO (claimed):44.2 hp
33.0 kW
That there looks like the problem is solved..... He can find one on the ground, road trip to grab it and be smiling and happy with a machine that meets his needs and expectations. Boom! Money!
   / My Thoughts On Modern Day Tractors #12
I have a 90 - 100 HP JD that I use for turf management as well as other things and I love it. Why on earth would you want live PTO?
I'm guessing he doesn't. He just used the wrong word to describe the PTO he wants.
PTO nomenclature has been so hopelessly messed up by manufacturing advertising that it makes more sense to just refer to the specifications.
And that's easy, because everyone wants the same thing:
They want a mechanical PTO that can be engaged and clutched independently of whatever the tractor is doing.
Most people call that a "fully independent" PTO. Whatever you call it, that's the gold standard... If you want the ability to run many PTO attachments that's what you want. And it has been available on US & European tractors for 50 years or more. Often it is an option.
The Ford 3000 has that PTO, so does our Kubota M series, and our 1958 JD.
rScotty
   / My Thoughts On Modern Day Tractors #13
Huh? This seems like a weird criticism. There are literally hundreds of compact tractor models available in our market. If you can't find one with enough PTO horsepower for your needs, you just aren't actually trying. Tell us what your criteria is and we'll tell you multiple candidates.
P.S. I bet you don't want to know how much those John Deeres in Europe cost to buy....
   / My Thoughts On Modern Day Tractors #14
If I was working the ground on 40 acres, I'd get a tractor just like that Ford 3000 - or anyone of a dozen others much like it that were built in that era. Their weight distribution was perfect for pulling. A FEL was functional....but it was an afterthought and added weight to an already heavy fore foot.
But today my work on our land is more of resculpting and sort of large scale landscaping. For that I want a tractor more set up for pushing and working with the FEL. For that I like the more modern tractors and especially the Kubota TLBs.
The real question is why on earth would John Deere build a tractor with a transmission driven PTO? That tractor is useless for anything other then pulling wagons and carts around.
Did you actually read my post? If not, go back and re read it.
That is not a medium frame size compact tractor.
   / My Thoughts On Modern Day Tractors #18
   / My Thoughts On Modern Day Tractors #19
What modern day tractor lacks the ability to run the pto with the tractor being stationary? I’m guessing none.
  • Good Post
Reactions: JWR
   / My Thoughts On Modern Day Tractors #20
Well I looked through that brochure, the only thing that I really noticed in there was the availability of a front 540 PTO and a front 3 point hitch.
Yes I would like to see those options offered on more tractors as well as multi speed PTO's including ground drive speed on the American models as well as the factory trailer braking hookups offered overseas
2016 MERCEDES BENZ SPRINTER (A58018)
2016 MERCEDES BENZ...
24in pin on excavator tooth bucket (A56435)
24in pin on...
2008 Ford Taurus SEL Sedan (A55973)
2008 Ford Taurus...
NEW Woods 6ft Finish Mower (A56436)
NEW Woods 6ft...
2018 Ford Fusion SE Hybrid Sedan (A56859)
2018 Ford Fusion...
BOSS 990 Fuel Trailer - 990 Gallon Farm Diesel Tank, Field Refueling Solution (A56435)
BOSS 990 Fuel...
