My third post: Best way to clear brush
   / My third post: Best way to clear brush #42
A drip torch looks like an oil can with a wick. It is a simple, stand-up way to start a fire in a field.
   / My third post: Best way to clear brush #43
<font color="#666666">
jeffinsgf
Thanks I've heard of one of them.
Where can I get one?
~~~~~~~~~ </font>
   / My third post: Best way to clear brush #45
<font color="blue"> we have a 4pm burning law here at this time of year, so that means I can only burn for a couple of hours
===== </font>
I don't think that's how it works.
Right now ours is ours 4 pm to 7 am. This does not mean that the fire has to be out by 7 am it means you can't start one between 7 am and 4 pm.
~~~~~~~~~It has nothing to do with how long a fire can burn only with when it can be started.
   / My third post: Best way to clear brush #46
IMO, the best way to clear brush is with a small dozer. Yes, it is more soil impacting, but the dozer can also repair the soil surface better than just about any other method.
I'm in the process of clearing 70 acres of brush. Honestly, I wouldn't consider even clearing 13 acres of it with a tractor and chain saw.
You can purchase a good used small dozer for $10 to $15k and resale it for virtually the same price. You can also rent one or hire the job done. In my area the going rate is around $225 to $250 per acre. The end result can be a beautiful pasture, clean fence rows, and all accomplished in a short amount of time. Good luck.
   / My third post: Best way to clear brush #47
Been there, done that and sold the small dozer for a tractor, FEL, BH, and BB. I then divided the work into "too big for me" and "good seat time". A small dozer is not the best tool for land clearing or grubbing a forest into a lawn. It is better than anything else at certain things but mostly inappropriate. Of course, a lot depends on the ground you will be clearing and your ability to stack a clean pile of slash. If there was just one machine a land clearing contractor had to have it would be aproperly sized excavator with a grapple on his bucket.
   / My third post: Best way to clear brush #48
CLEAR UNDERBRUSH AS A SIDE JOB. I HAVE FOUR FORKS (MADE BY BUSH HOG)THAT BOLT INTO MY BUCKET THEY ARE ABOUT 1 1\2 W 3\4 THICK AND ABOUT 4 FEET LONG, THERY ARE CALLED MANURE FORKS. YOU CAN PICK UP WHOLE TREES AS LONG AS YOU BALANCE THEM. THEY HAVE ONE HOLE IN THE BACK AND YOU CLAMP THE FRONT. THE ARE LIKE T1 STEEL SO DONT BURN OR DRILL ON THEM THEY WILL BRAKE.
L3410DT W/KUBOTA LOADER
   / My third post: Best way to clear brush #49
I have about the same arrangement you describe, about 8 acres pasture, 10 acres woods.
I just cleared some of the woods for a bigger back yard ( house is centered in the woods). i didn't want to take down any big tress, but there was a lot of brush and saplings in there to be removed.
I did all the clearing with FEL and a landscape rake.The only time I needed the chain saw as for the vines hanging from the trees i didn't want to damage.
I'm not sure how big your tractor is, but my Deere 4120 (about 3700) lbs with R4's, woukld make quick work of small trees.
I just raised the loader bucket up high for good leverage, and slowly pushed them over, being real careful not to store a lot of energy in a bent over tree. Sometimes I had to hit them from more than one side, sometimes digging the loader in low to flip the root ball out. Being new to tractoring I am amazed what a FEL can do.
For small bushes and growth I got real good at just hitting them right where they came out of the ground with the edge of the fel and pulled them right out, roots and all.
I found having the bucket level indicator set right is a key, then the bucket can be set and pushed along right above or right below ground level, whatever works best for the spot you are in.
i used the landscape rake for clean up and "blending". I removed two of three tines because it was pulling too much dirt. After i got the big stuff out of the way, I put all the tines back, set it to a more agressive angle and it really cleaned up the land nice.
As i said, i am amazed what a tool an FEL is. It can really wreak some havoc, and i am sure many people have been hurt running a tractor with one. During the job, there were many times were if I wasn't careful, very bad things could have happened.
The man seat pucker incident i encountered with this job was due to the landsacpe rake. How can a lanscape rake be dangerous? Well i was pulling debris to a cenral location, attempting to make straight passes and get as close a possible to the trees i was passing so as to not leave a lot of junk around the trunks. I went by a small tree a little too close. The tree was small enough that the tractor and rake pulled it right down. If the tractor didn't have ROPS, that tree would have crushed my skull. Be carefull out there!
My big question is what to do with my pile of junk? The house is on a well, so I don't have a lot of water if I needed it. The pile is in the middle of the woods somewhat near the house. I would be too nervous about burning it.
i was thinking of renting something to dig a hole to bury it. It would need to be a big hole, and I guess I 'd need to leave a mound to account for settlement. The mound doesn't sound too attractive either, and i really don't have a feel for how much and how long it would take to settle.
Today I limed, fertilized and seeded. I'm not looking for a golf course lawn or anything, just decent coverage. Being that this area will be somewhat shaded, do I need to cover with straw? I'm in south central, PA.
JT
   / My third post: Best way to clear brush #50
"My big question is what to do with my pile of junk? The house is on a well, so I don't have a lot of water if I needed it. The pile is in the middle of the woods somewhat near the house. I would be too nervous about burning it."
Good question. I spent Saturday and part of Sunday chipping away at my slash pile by burning. A tractor is an effective fire stacker. I start a fire and feed it with the tractor to keep the fire at a reasonable size. Not buring all at once like the pros. It is amazing how much slash comes out of a small area of woods. I have found it much better to mow everything small enough to be mowed with the brush hog and then stack the logs in a nice neat pile to be used for firewood or for another fire someday. This reduces the pile considerably.
My pile is down to 90'x30' by 8' tall. I knocked the length down 20 feet to 90' after a weekend's burn. I actually push small heaps into the burning fire so as not to light off the whole 90'. You don't need water, you need a controlled burn that is reasonably small and not under a tree.
206320 (A57192)
206320 (A57192)
2022 John Deere 4052M MFWD Compact Utility Tractor with 400E loader - Bucket, Forks and Grapple (A55314)
2022 John Deere...
2019 Merlo TF 42.7 (A60462)
2019 Merlo TF 42.7...
DRAGON 500 BBL FRAC TANK (A58214)
DRAGON 500 BBL...
Nissan Forklift (A55973)
Nissan Forklift...
2018 KOMATSU WA320-8 WHEEL LOADER (A60429)
2018 KOMATSU...
