My third post: Best way to clear brush
   / My third post: Best way to clear brush #11
Very cool historical site. Amazing....
Think about driving into the mess with a chain and just chaining onto the saplings/trash wood and pulling them out by the roots. Then put it aside and keep pushing in. Gather up the mess on the way out by piling onto the loader arms, between the arms and the back of the bucket. Carry a bunch to the burn pile and dump. You'll need chain hooks welded to the sides of your bucket or a D ring welded inside the bucket so you can cleanly pull the junk out by the roots.
   / My third post: Best way to clear brush #12
miltrade,
I just got a DR Mower to help clear out the brush around the house. The tractor is just too large to get into most areas of the woods and at this time of the year some areas are too wet as well. The DR can get in there and cut up 2.5 inch diameter saplings. My MX6 is rated to cut the same size material. I'll still have to get in a use a chainsaw on down trees and limbs but the DR clears the way for the chainsaw.
I'll use the tractor to take out pallets of firewood. Tops and trash I think I'm just going to leave in place and just rot. The DR does a good job of mulching up most of the saplings it cuts down so only large stuff falling from/with trees will be left.
Later,
Dan
   / My third post: Best way to clear brush #13
Sound, The problem I've had here with cutting is that six weeks later the mess is worse than before because the saplings now have twice as many stems! I suppose if you cut it off close to the ground it should kill most trees, however a lot of "trash" trees will root sprout. One also then encounters the problem of cutting perfectly straight so you don't have sharp stems sticking up ready to get somebody or a tire. I've had good long term luck with a few wraps of a medium sized chain and bit of throttle /forums/images/graemlins/smile.gif
dmccarty , the idea of leaving the stuff to rot is the reason I am trying to get this stuff cleared in the first place. Local folks in the area with knowledge tell me that the fallen logs and rotting wood are the prime breeding grounds for deer flys, horseflys, ticks, and snakes. I have been on the property through one summer and the deerflys were so bad I had to basically dress in a biohazard suit to even go outside to work, regardless of how hot it was. I want to create an environment outside my pastures that are basically clean and clear of everything except for large trees. Then, in the spring and summer, I can just run through there with my three-point brush mower and keep everything clean.
JimMorrissey, is it recommended/feasible to pull the saplings out using the drawbar or is the FEL essential? Seems to me that using the FEL for this purpose subjects the hydraulics and hoses etc. to unnecessary strain.
   / My third post: Best way to clear brush #15
miltrade,
If you have to remove the brush, your options are fire, chipper, and FEL work. /forums/images/graemlins/grin.gif
Like I said the DR Mower does a pretty good job of mulching what it cuts. Bigger sapplings don't seem to get mulched as much. If you leave a stick on the ground that should not be a breeding ground or hiding place. If the stuff its just lying on the ground rotting I would not think you would have as much of a bug/snake problem.
Ticks and chiggers we have. Chiggers and tick like plants that are 12-24 inchs tall. At least in my area. Especially chiggers. Keeping this kind of brush cut down does help. BUT as long as you have deer and other animals feeding the tick and chiggers you are going to have tick and chiggers. /forums/images/graemlins/blush.gif I think the only way to really remove them is with controlled burns.
I don't go into my woods in from spring until the first freeze without dressing for ticks and chiggers. Mowing should keep the chiggers down but ticks will still be there but hopefully reduced. I have been the host of quite a few chigger infestations. I ALWAYS pick them up in grass/brush 12-24 inches tall. Momma chigger likes to lay the eggs on brush that will rub up against an animal. I'm not sure she would lay that on dead wood. I know I have never gotten chiggers from dead wood. Ticks will be in the leaf litter as well as grass/brush. I won't say I have not picked up ticks from dead wood but there would be dang few. Usually its the same scenario with chiggers as with ticks. 12-24 inch tall grass/brush. BUT I have seen ticks running across gravel to get to me. They see ya they will run for ya. Ye just need to move faster or see them first. /forums/images/graemlins/blush.gif
If you have piles of wood that might attract the snakes. But I don't think it will do much for the ticks and chiggers. I have noticed that the bitting flies seemed to like tall grass/brush. Remove it and their population decreases.
You can use your FEL to pull up saplings with no strain. I have notice the DR Mower will pull some saplings out of the ground before munching.
Pallet forks are really useful to carrying large amounts of brush. You have to manually stack it on the forks or pile the brush up first so the forks can get under it but it works pretty well.
Later,
Dan
   / My third post: Best way to clear brush #16
miltrade,
another option might be to rent a skid steer with a flail mower attachment on the front. you could at the same time rent a root grapple for it. you could use it to clear all the brush and small trees up to 3"-4". then clear all the trash with the root grapple. you would still have to clean the larger stuff but at least would be working in a clearer area. and you wouldn't be worried about damage to your tractor.
good luck,
metin
   / My third post: Best way to clear brush #17
I have about 20' of cable that has a clevis on one end and a clip on the other end. This saves wrapping a chain around brush. I back up to a honeysuckle or multiflora rose, wrap the cable around it, snap the clip and then get back on the tractor and pull. Once it is out, I use the FEL to push things into a pile to burn.
Another option that I have found useful is to back up with the box blade, hit the offending brush a bit high and then come in low for a second pass. Last week it was really nice here in Illinois and I pushed out a lot of honeysuckle, goosberries, and multiflora rose.
The biggest thing in my mind is to either work at it slowly or spend $$$ to hire someone to bulldoze it out. I have a lot of wild flowers in the timber and prefer to use the lower impact method.
   / My third post: Best way to clear brush #18
I just watched the action video. All I can say is HOLY ****!!!
I don't want to be anywhere in line-of-sight when someone is grinding standing trees with that thing.
Awesome destructive power tho...
   / My third post: Best way to clear brush #19
HA! The outfit I hired is a retired guy who does the bidding and a youngin that runs the machine, on the weekends. After I showed the older guy what I wanted done and he concurred that it would be about a half days work, I commented on what a b!tchen machine it was cuz I looked it up on the net. He said, yeh. Then he moved a sparse lock of hair to reveal about a 1" gash, healing, on his upper forehead. He added that he was 150' away when he got tagged. I said, cool. He didn't seem to appreciate that. I don't think he's lived in these hills all that long /forums/images/graemlins/smirk.gif
   / My third post: Best way to clear brush #20
Last time I saw that much shrapnel, I was wearing a flak vest and diving for cover. Still spent a couple of hours getting excess hardware removed.
2010 KMC 3376 Peanut Combine (A56438)
2010 KMC 3376...
207279 (A52708)
207279 (A52708)
2002 AMERITRAIL 32FT GOOSENECK TRAILER (A58214)
2002 AMERITRAIL...
2018 FREIGHTLINER CASCADIA TANDEM AXLE SLEEPER (A59905)
2018 FREIGHTLINER...
2003 LEEBOY L150 ASPHALT DISTRIBUTOR TRAILER (A52707)
2003 LEEBOY L150...
Toro Three wheeler sand pro (A56859)
Toro Three wheeler...
