My Stupidity kicked in at full throttle.
   / My Stupidity kicked in at full throttle. #11
It's fascinating how many ways there are to do something.... just how much work people will gamble against how much risk they are willing to take.
Chaining it to a tree and driving forward will probably accomplish something, but you don't have any control over what that might be. It might even be the PTO Housing or even the rear end casting that comes loose..
I would try that idea with the ratchet strap first. It's pretty safe. It appeals to my own bias towards solving problems with more work and less risk to expensive parts.
If that didn't work, my next move would be even more conservative. I'd take the PTO shaft apart until it was possible to put a standard gear puller onto the coupllng. That might involve some hacksawing and a new PTO shaft, but it insures that pulling the coupling off won't do any farther damage to the PTO. And there is zero chance of damaging the PTO housing
rScotty
This makes sense.
The chain and drive forward method sounds like something I would do, after getting frustrated and when I should be walking away from it for a while.
   / My Stupidity kicked in at full throttle. #12
This is not a problem it went on and it will come off, I wouldn't hesitate at idle to engage the PTO and let it turn for a few minutes and I would start with a large screwdriver slid in the middle of the yolk so I could apply pressure by pulling with both hands, as others have said apply penetrating oil first and don't hook a chain and start snatching or pulling just take your time and it's going to slide back off.
   / My Stupidity kicked in at full throttle. #13
I think I read that he beat it on. That was the first mistake. I've never owned a tractor that had the PTO spline powdercoated.
   / My Stupidity kicked in at full throttle. #14
I've had regular paint on a brand new Deere pto shaft have to be removed before it's first use.
Apply tension to the shaft and apply hammer to alternating sides of the yolk. A little spray juice will make you feel better and might help slightly. 😉
Patience and persistence my friend, once off sand, scrape or remove what paint you can and grease the ever living he!! out of both parts and try again.... without hammering. 👍
   / My Stupidity kicked in at full throttle. #15
I bought a new 2024 Mahindra 1126 tractor. I have put around 70 hours on it. Until this past Saturday it had never had it's PTO stub uncovered. When I took the cover off the stub looked very smooth and black. I intended to connect a new 48" rotary cutter to the tractor. Every thing looked good and clean in the PTO shaft yoke.
Well the shaft went on to the stub about 1/2". From there I used a block of wood and drove it on, as far as it would go. About 1/4" from the lock pin groove.
My thought when driving it on was that it would free up while I was using it. But I ain't gonna use it for fear that the shaft will free up and sling off.
Now to my question. Does anyone have any suggestions as to how I am gonna git the shaft off. I am disconnected from the rotary cutter with the cutter end of the drive line separated from the tractor end of the drive line.
My thought is to tie the shaft to a tree and drive off with the tractor.
I am open to any other ideas.
When I git this apart I will be cleaning the powder coat paint off of the stub.
Mule
So there was no grease on the PTO stub when you attached a rotary cutter?
   / My Stupidity kicked in at full throttle. #16
A few of my PTO driveshafts have grease zerks on the spline coupler. If yours has one, remove the zerk and rotate the PTO shaft until the hole is pointing upward. Fill the hole with penetrating oil, I prefer Kroil, and let it sit. refill as needed. Then, as others have suggested, apply tension with a ratchet strap and tap the fitting.
If that doesn't work, remove the U joint and use a 3 point puller.
I would NOT use the tractor / tree method. Too much risk of catastrophic damage.
Good luck!
   / My Stupidity kicked in at full throttle. #17
The safest and by far most effective way to remove it is with a makeshift slide hammer.
First remove the plastic shield, then drill a small hole maybe 5/16 or 3/8” near the end of the shaft.
Get a 10 or 25 lb cast iron dumbbell and slide on the shaft, put a rod or bolt with head removed through the drilled hole , this will be your slide stop.
Grab the dumbbell with both hands and rap it against the stop. I’ll guarantee it will come off with out much of a fight.
   / My Stupidity kicked in at full throttle. #18
large capacity skid steer bucket (A56857)
large capacity...
2019 ALLMAND BROS, INC. ALLMAND BROS, INC. (A55745)
2019 ALLMAND BROS...
2012 PROCO 130BBL VAC TRAILER (A58214)
2012 PROCO 130BBL...
2012 INTERNATIONAL PROSTAR+ (A58214)
2012 INTERNATIONAL...
2019 GALYEAN 150BBL STEEL (A58214)
2019 GALYEAN...
2020 PETERBILT 567 (A58214)
2020 PETERBILT 567...
