My simple cure for running warm
/ My simple cure for running warm #1
Nightrain1
Southern Illinois
Mahindra 3510 / Bad Boy 28hp cat diesel
I have had my 3510 for a couple years and have read post about overheating since day one. Never have had any overheating problems myself but the other night, I had to make about a 5 mile run to pick up an old wagon. I noticed it kept creeping up about 3/4 on the gauge which was warmer then normal. I knew my screen was finally clogging up. My cure was the ole leaf blower. I prefer it over washing out the radiator and clogging the fins with mud but either way would work. Just a thought because I have'nt seen anyone mention cleaning it with the leaf blower but it really works well.
/ My simple cure for running warm #2
I clean my with my air compressor. I found that the flexable tubes for a grease gun has the same threads as my air gun, so I cleaned out the tube and attached it to the air gun. Now I can bend and twist it around the fan and shroud to get the radiator really clean. It always amazes me how much dust gets into there!!!!
Eddie
/ My simple cure for running warm #3
I use a Shop Vac. Pull the stuff out the same direction it went in.
Good ideas all around, I try to blow it from behind the motor also. No need in running it through the radiator. I did go from the front after getting all that I could from the backside first. I also hit the pre filter, blowing it out backwards also. There was quite abit more dust then I thought. You would want to be careful useing an air compressor here as some claim it tears the filter fiber up, eventually letting dust by.
/ My simple cure for running warm #5
I, too, always used my air-compressor. I just used a regular 2' blow gun; never thought about trying Eddie Walker's grease gun hose, but it sounds like a good idea to me. Of course, even with the little rubber tip on my 2' blow gun, I try to not touch the radiator fins and to blow straight from back to front so as to not let the air pressure bend any fins.
/ My simple cure for running warm #6
Eddie & Bird,
Nice to see y'all lurking around down here.:) I had no idea y'all were intereseted in Mahindra tractors;)
hugs, Brandi
New/Unused Landhonor Toolbox with 24 Ratchet Straps (A65583)
New/Unused...
2006 Kawasaki Bayou 250 (A64127)
2006 Kawasaki...
16ft T/A Utility Trailer (A64557)
16ft T/A Utility...
2025 SDLanch SDLL60 Mini Stand-On Track Loader Skid Steer (A64553)
2025 SDLanch...
2020 INTERNATIONAL MV607 26 FT BOX TRUCK (A59905)
2020 INTERNATIONAL...
2014 CATERPILLAR 938K WHEEL LOADER (A64279)
2014 CATERPILLAR...
