My simple cure for running warm
   / My simple cure for running warm #1
Nightrain1
Southern Illinois
Mahindra 3510 / Bad Boy 28hp cat diesel
I have had my 3510 for a couple years and have read post about overheating since day one. Never have had any overheating problems myself but the other night, I had to make about a 5 mile run to pick up an old wagon. I noticed it kept creeping up about 3/4 on the gauge which was warmer then normal. I knew my screen was finally clogging up. My cure was the ole leaf blower. I prefer it over washing out the radiator and clogging the fins with mud but either way would work. Just a thought because I have'nt seen anyone mention cleaning it with the leaf blower but it really works well.
   / My simple cure for running warm #2
I clean my with my air compressor. I found that the flexable tubes for a grease gun has the same threads as my air gun, so I cleaned out the tube and attached it to the air gun. Now I can bend and twist it around the fan and shroud to get the radiator really clean. It always amazes me how much dust gets into there!!!!
Eddie
   / My simple cure for running warm #3
I use a Shop Vac. Pull the stuff out the same direction it went in.
Good ideas all around, I try to blow it from behind the motor also. No need in running it through the radiator. I did go from the front after getting all that I could from the backside first. I also hit the pre filter, blowing it out backwards also. There was quite abit more dust then I thought. You would want to be careful useing an air compressor here as some claim it tears the filter fiber up, eventually letting dust by.
   / My simple cure for running warm #5
I, too, always used my air-compressor. I just used a regular 2' blow gun; never thought about trying Eddie Walker's grease gun hose, but it sounds like a good idea to me. Of course, even with the little rubber tip on my 2' blow gun, I try to not touch the radiator fins and to blow straight from back to front so as to not let the air pressure bend any fins.
   / My simple cure for running warm #6
Eddie & Bird,
Nice to see y'all lurking around down here.:) I had no idea y'all were intereseted in Mahindra tractors;)
hugs, Brandi
COUNTER WEIGHT (A51243)
COUNTER WEIGHT...
John Deere 970 Cultimulcher (A52128)
John Deere 970...
Farm Star 4' Off Set Disk (A50515)
Farm Star 4' Off...
UNUSED FUTURE MINI EXCAVATOR HYD THUMB (A51244)
UNUSED FUTURE MINI...
2020 CASE CX37C EXCAVATOR (A51242)
2020 CASE CX37C...
2022 Chevrolet Tahoe FL SUV (A51694)
2022 Chevrolet...
