My Senior design project - a "Swamp Thing" tracked vehicle clone
   / My Senior design project - a "Swamp Thing" tracked vehicle clone
Springtime update! We didn't get much snow here this winter so I only drove Snowzer around a few times when there was sufficient snow on the ground needed to reduce lawn damage. Since I have to keep the wife happy I got to thinking how I could make the tracks less aggressive. The easiest way to do that would be to box out the grouser channels by welding a flat strip over them - all 126 of them. In the attached image, you can see both the original and modified grousers. I hope this works!
   / My Senior design project - a "Swamp Thing" tracked vehicle clone #662
Could do them at a 45 for pretty much the same volume of work. :unsure: Side hill slippage will suffer. :eek:
Hi Arly, I'm not sure by what you mean by 45. Yes, I would assume it might slide a bit sideways which should not be an issue in my yard. The next owner can fix that. ;)
The original grousers were plasma cut from 1" sq. tube x 14" long and 3" from each end were beveled (sloped) down by 1/4". To modify these I first cut the channel ends at 45° and then box the channel by placing a thin strip (1/8 x 7/8" x 14-3/4" long) on the open top and tig welding it down. I then grind a groove in the strip near each end to weaken it and hammer it down to the bottom corner. The remaining joints are then tig welded to seal it. I tried to mig it initially but even using .023 wire put down bigger weld beads than I wanted. I am using 1/16" ER70S-6 tig rod which works nicely and looks good.
   / My Senior design project - a "Swamp Thing" tracked vehicle clone #666
I may try that! :cool:
   / My Senior design project - a "Swamp Thing" tracked vehicle clone #668
My grousers are 1.25” square tube and turn easy, side hill ok, but definitely don’t bite as well as a more traditional grouser.
My grousers are 1.25” square tube...
Please post a photo or two of your grousers/tracks. TY.
   / My Senior design project - a "Swamp Thing" tracked vehicle clone #670
New/Unused CFG Industrial MX15RX Mini Excavator (A54865)
New/Unused CFG...
KJ 20' Metal Farm Driveway Gate (A53314)
KJ 20' Metal Farm...
2008 KZ Sportsman Police Bunk 5th Wheel Tri-Axle Travel Trailer (A54815)
2008 KZ Sportsman...
2013 International DuraStar 4300 Crew Cab Mason Dump Truck (A55788)
2013 International...
Simplicity Legacy Lawnmower (RUNS) (A50775)
Simplicity Legacy...
2007 Ford Expedition EL Limited 4x4 SUV (A55758)
2007 Ford...
