My Senior design project - a "Swamp Thing" tracked vehicle clone
   / My Senior design project - a "Swamp Thing" tracked vehicle clone #651
I could but my engineering degree is all my psychotic/neuroticsm with no actual degree, and my fabrication skills are rudimentary with only the simplest of tools. Which is why I admire the Russian builds.
Please don't let that stop you from posting, most of us are just fooling around building or repairing things. Never know when someone has a good idea that can help another out. Your rig looks pretty cool and it's functional which is the main thing.
   / My Senior design project - a "Swamp Thing" tracked vehicle clone #652
Did your bilge pump fans remedy the hot brakes? Mine are getting too hot in some situations and I have to stop to let them cool. Might have to try your concept.
I think the fans helped a bunch although I've not really pushed it through the paces. I think switching to the higher pressure hydraulic brake steering system makes steering more efficient and quicker. The fans were cheap and easy to install.
   / My Senior design project - a "Swamp Thing" tracked vehicle clone #654
Thanks. My machine turns on a dime but it’s also very light. Plowing driveways and cruising in the yard works fine, but grinding up mountains today in a couple feet and using brakes more they got soft from the heat.
It won't turn on a dime on grass - just ask our buddy Arly!
BTW, how are you applying pressure to the steering brake calipers? Auto master cylinders?
   / My Senior design project - a "Swamp Thing" tracked vehicle clone #657
Yeah blacktop and grass I won’t go near. Gravel and snow, sure.
I’m using four (two per side) UTV calipers from a Razor 1000 basically. Each has their own cylinder, so lever pushes two at a time. If the air is purged well, it’s very light lever pressure to pull and create turn.
But in deep snow that requires a lot of corrective action, they do get hot.
I ordered some bilge blowers. I’ve ran mine with the back cover off and it definitely helps.
I think real snowcats like Bombi/Imp/Spryte have brake bands in an oil bath.
   / My Senior design project - a "Swamp Thing" tracked vehicle clone #658
Would hydraulic drive solve the braking and heat problem? Obviously you would need to cool the hydraulics. I think hydraulics are how all modern tracked machines are propelled and braked.
   / My Senior design project - a "Swamp Thing" tracked vehicle clone #659
Yes, but hydrostatic systems can add 3500-5000$ to build cost.
I don't think I spent that much to build my entire machine.
Butterfly Artwork (A55758)
Butterfly Artwork...
Hyster H90FT 8,000lb Diesel Forklift (A55973)
Hyster H90FT...
2015 Ford F-150 4x4 Crew Cab Pickup Truck (A56858)
2015 Ford F-150...
3 Forks (A56857)
3 Forks (A56857)
2011 Isuzu NPR 14FT Box Truck (A56858)
2011 Isuzu NPR...
2025 Swict 84in Bucket Skid Steer Attachment (A56857)
2025 Swict 84in...
