My Senior design project - a "Swamp Thing" tracked vehicle clone
   / My Senior design project - a "Swamp Thing" tracked vehicle clone #651
I could but my engineering degree is all my psychotic/neuroticsm with no actual degree, and my fabrication skills are rudimentary with only the simplest of tools. Which is why I admire the Russian builds.
Please don't let that stop you from posting, most of us are just fooling around building or repairing things. Never know when someone has a good idea that can help another out. Your rig looks pretty cool and it's functional which is the main thing.
   / My Senior design project - a "Swamp Thing" tracked vehicle clone #652
Did your bilge pump fans remedy the hot brakes? Mine are getting too hot in some situations and I have to stop to let them cool. Might have to try your concept.
I think the fans helped a bunch although I've not really pushed it through the paces. I think switching to the higher pressure hydraulic brake steering system makes steering more efficient and quicker. The fans were cheap and easy to install.
   / My Senior design project - a "Swamp Thing" tracked vehicle clone #654
Thanks. My machine turns on a dime but it’s also very light. Plowing driveways and cruising in the yard works fine, but grinding up mountains today in a couple feet and using brakes more they got soft from the heat.
It won't turn on a dime on grass - just ask our buddy Arly!
BTW, how are you applying pressure to the steering brake calipers? Auto master cylinders?
   / My Senior design project - a "Swamp Thing" tracked vehicle clone #657
Yeah blacktop and grass I won’t go near. Gravel and snow, sure.
I’m using four (two per side) UTV calipers from a Razor 1000 basically. Each has their own cylinder, so lever pushes two at a time. If the air is purged well, it’s very light lever pressure to pull and create turn.
But in deep snow that requires a lot of corrective action, they do get hot.
I ordered some bilge blowers. I’ve ran mine with the back cover off and it definitely helps.
I think real snowcats like Bombi/Imp/Spryte have brake bands in an oil bath.
   / My Senior design project - a "Swamp Thing" tracked vehicle clone #658
Would hydraulic drive solve the braking and heat problem? Obviously you would need to cool the hydraulics. I think hydraulics are how all modern tracked machines are propelled and braked.
   / My Senior design project - a "Swamp Thing" tracked vehicle clone #659
Yes, but hydrostatic systems can add 3500-5000$ to build cost.
I don't think I spent that much to build my entire machine.
1997 Perkins 75KW Towable Diesel Generator (A56857)
1997 Perkins 75KW...
2019 FREIGHTLINER CASCADIA TANDEM AXLE SLEEPER (A58018)
2019 FREIGHTLINER...
2006 Keystone Laredo 29RL 31ft. T/A 5th Wheel Travel Trailer (A55853)
2006 Keystone...
2015 Freightliner Bucket Truck (A55973)
2015 Freightliner...
2017 FREIGHTLINER M2 106 (A55745)
2017 FREIGHTLINER...
UNUSED FUTURE 32"...
