My Senior design project - a "Swamp Thing" tracked vehicle clone
   / My Senior design project - a "Swamp Thing" tracked vehicle clone
Willy - I looked at a bunch of pricey options and I had a bunch of free hardwood I could use to make wheels. They are all installed and I took Snowzer out for a ride and they appeared to work just fine. What additional support are you suggesting that steel sides would provide? FWIW, each wheel normally supports about 500 lb.
   / My Senior design project - a "Swamp Thing" tracked vehicle clone #622
Too bad you can't get air bags for your suspension.
   / My Senior design project - a "Swamp Thing" tracked vehicle clone #623
Would it be possible to do something simpler like a leaf spring centered upside down with the ends pushing down on the pivoting arm? Like the old school front suspension on a Ford Model A.
I wouldn't think there's be enough room for leaf springs under there. Thanks for the feedback!
I've been playing around with designing an electro-hydraulic pressure control system for the brake steering. Instead of using a master cylinder for each rotor, I thought a small hydraulic pump could be used to increase the net pressure at the calipers. I set up a small test system (yes, that is a HF 12v drill motor) a while back and was able to see 3600 psi on my 4000# pressure gauge (see first photo). When I checked into the availability of another pump kit, I found they were no longer available. I bought another small pump and will be testing it out soon once I plumb it up (2nd image). The third image shows what a dual pump setup may look like. I envision using a roller chain setup connected to each steering arm to rotate a ball valve to control the pressure. Will it work?
I ran the test hydraulic setup today and got over 3600 psi out of it. The poor little HF drill motor was not happy at all and was very noisy. I may buy a used 12v Dewalt drill and try it instead as I'll bet it has a bit more power and would last longer.
   / My Senior design project - a "Swamp Thing" tracked vehicle clone #627
You might want to check to see how much pressure the brake calipers will take. I don't think that they are design for such high pressure.
You may be right and plan B would be to use lower pressure of say 2000 psi and use the two service calipers for additional steering friction. The service brake would then move to a new rotor and caliper mounted to the input of the front diff. I looked at calipers used on Audis and VWs that incorporate a manual parking brake lever which may be a useful feature. I think I covered this in an earlier post.
   / My Senior design project - a "Swamp Thing" tracked vehicle clone #629
How are your wooden wheels working out?
Due to a lack of snow here, I have only tried them out a little bit so it's too early to tell.
2019 DRAGON ESP 150BBL ALUMINUM (A58214)
2019 DRAGON ESP...
2019 DRAGON ESP...
78" ROCK BUCKET (A52706)
78" ROCK BUCKET...
Rooster Artwork (A55758)
Rooster Artwork...
2013 Ford F-150 4x4 Crew Cab Pickup Truck (A55852)
2013 Ford F-150...
flooring (A55758)
flooring (A55758)
