My RX7320 is home.
   / My RX7320 is home.
Quick and dirty grill guard. A bread tray and zip ties. It's temporary.
   / My RX7320 is home. #72
Good idea
   / My RX7320 is home. #73
...By investigating the vibration noise from the kickstand, I discovered where the lost nuts had come from. I will try to snap a picture today. But I found that I had lost 3 nuts (I had recovered 2 of them) from inside that kickstand...they they were spinning with vibration and had come off. I replaced them with the locking type and that was quickly fixed. Today I will be checking around to order some new scarifier blades.
WoodChuckDad; Did you post a picture of the FEL kickstand nuts and bolts? I may have the same issue. I want make sure I am looking in the same area. Thanks in advance.
Yesterday, the first thing we did at the farm was put the fork lift blades on the tractor and take the new excavator bucket off the truck. My wife was watching and waved at me. She wanted me to know the tire was low, and pointed toward the back of the truck.....I thought. I said I had seen it and she moved away and I started moving backward with the pallet. When I turned the wheel to move forward, I heard a woopie cushion noise and felt the front tire of the tractor give way. Set the pallet with excavator bucket down and backed up. Flat tire. Ok, now I need to jack that up.....with what??? I looked around and about 20 feet away was rise at the side of the driveway. I drove over to that, used the FEL pushing downward, then angled the forks downward a bit to life enough to take off the tire. And yes, I know this was dangerous for a number of reasons. It had the short hairs tingling while I did it, but we needed the tire off and that was all I had to work with. We headed off toward town, trying to figure out where I was going to go. I stopped at the general store to ask there, since it seems to be the gathering place for the The local farmers, etc. I was introduced to an older man was leaving with his grandson. He said to follow him, and he took me down the road a mile and onto his farm. We fixed the tire at the shop. He was 84 years old. Wouldn't let me pay him anything....I think I made a friend. I'm sure we will see him again. He is also a welder....still working. And a neighbor dropped by with a piece from a lawn tractor that needed welding. We swung by the local hardware shop on the way back and got a 12v tire inflater compressor. I"ll be checking tire pressure on a weekly basis. Just to maintain.
   / My RX7320 is home. #76
I have found that the neighbors are very friendly too. We we could not get up the driveway this winter a neighbor brought over his tractor and box blade and did my driveway so we could get up. Another neighbor welded a piece that broke on the yanmar too. so far they have all been very nice. I will be moving in a few weeks so I will be able to play with my tractor all the time. Now it is just mow and move brush and trees for three or four hours and then back on the road home.
We have been laying into the tractor pretty good. My Son in Law has been using it to skid logs the last two weekends. I wish I had a 3 point attachment for the logs. We are just using chain wrapped around the top of the box blade. Its doing a number on the top edge of the blade, but it's holding up well and it works.
I need to check the hours on the tractor...I'm sure we are closing in on 100.
   / My RX7320 is home. #78
I would think an attachment would be the best thing. I am thinking of getting one as I have so many logs to move. They selectively timbered my lot and I want to open it up the rest of the way too.
   / My RX7320 is home. #79
I just sold bobcat ct450 I was looking at the RX Line over the NX I have always had hydro. How does the power shuttle work on these tractor? Thank you
   / My RX7320 is home. #80
Power shuttle works well to change foward and reverse. I find I have to shift gears a couple times when I am doing loader or grapple work. I pull up in low but might move down to the creep speed to actually pick up the object. For mowing it is great, I just set it and drive and I can back into places by just moving the shuttle. If you will be primarily doing leader work the hydro is sweet but I found that I wanted a bigger frame size so it was not a choice. I do not miss having it most of the time. I just choose the gear and go.
2013 Digger Derrick (A50323)
2013 Digger...
2012 Ford Edge SUV (A50324)
2012 Ford Edge SUV...
Agway AccumuL8 Grabber (A50515)
Agway AccumuL8...
2018 RoGator 1100C (A52128)
2018 RoGator 1100C...
2005 TerraGator 8104 (A52128)
2005 TerraGator...
John Deere 1770 Conservation 16 Row Planter (A50774)
John Deere 1770...
