My PTO stopped working
/ My PTO stopped working #1
grsthegreat
Super Star Member
north idaho
Kioti DK45SE hst cab
I have an electric over hydraulic PTO system on my tractor that occasionally stops working and I have to flip toggle switch 5-10 times before it comes to life. Worked ok all summer, but i was dreading issues come winter.
Just to be safe i ordered the twin relay and a new toggle switch from Kioti dealer. I dont like to just throw parts at a problem, but for less than $80 including shipping i thought...what the heck. Parts arrived within a week but sat on shelf due to hectic schedule.
Yesterday i completed install on all winter items...chains, hydraulic pump and tank, hoses and blower. Went to test it and lo and behold...nothing.
Got out the service manual and proceeded to tear apart dash to install new parts. Come to find out that the pto ground wire sits behind the plastic dual relay and was loose. Also, the paint on dash wasnt scraped behind ground wire. I scarred up paint, replaced the relay and switch with new ones (had them anyways but kept old also) and fired it up. Works like original.
I probably didn't need the parts, but i didn't want to be stuck in winter snow without a working PTO.
/ My PTO stopped working #2
Nicely done. Interesting how often grounds are problematic.
/ My PTO stopped working #3
98.43% of all electrical problems on TBN are answered with: "Check your ground connection" for a good reason.
78.32% of the time this is the exact problem.
(p.s. 85.43% of the statistics you see on the internet are made up on the spot. Sometimes it's 100% :rolleyes:)
/ My PTO stopped working #5
I'm glad you solved the problem, many people don't realize that the ground side is just as crucial as the hot side in completing the circuit.
UNUSED HYD THUMB (A60432)
UNUSED HYD THUMB...
(4) ROADGUIDER QH100 235/80R16 TIRES (A60430)
(4) ROADGUIDER...
UNUSED SET OF FUTURE 13', 200AMP JUMPER CABLES (A60430)
UNUSED SET OF...
UNUSED RAYTREE RMBD72ST-72" HYD DRUM MULCHER (A60432)
UNUSED RAYTREE...
2007 JCB 3CX BACKHOE (A60429)
2007 JCB 3CX...
INTERNATIONAL EAGLE ROAD TRACTOR (A52707)
INTERNATIONAL...
