My PT-422 mods
/ My PT-422 mods #1
KMA
Owego, NY
PT422 w/ EH72FI engine swap
I've posted some of these previously, but I added a few more "upgrades" and thought I'd post some pics. Thanks to all the forum members for the ideas and inspiration for most of the changes. :)
My tractor:
10" cooling fan:
Spinner knob on steering wheel:
TSC springer seat:
Mini hoe bucket curl and quick attach lock/unlock lever:
Tail light for safety (and shines just bright enough to help with backing up at night):
Light bar:
/ My PT-422 mods #2
Everything looks great, i need the mini-hoe lever set up you made. By chance could i get u to sell ,or make one for my 422? I have cash and everything!!! If I could get my hands on one in the next couple of weeks, my back would appreciate it.
Thanks Trogger
P.S. I did see your thread on this modification but I still need a little help.
/ My PT-422 mods
Red Zebra said:
Nice PT! I like the "organic" Armor-all on the tires!
Thanks. :D And I just washed it a week ago. :eek:
/ My PT-422 mods
Thanks Trogger
I wish I could help you out, but I just don't have much time lately. :( We just finished building our house and I'm trying to finish up the landscaping, etc... between work, my kids baseball games, and the house I just don't get much free time. The only other thing I do is play on a competition paintball team. Any small gaps left over, I try to fill in with some sleep. :eek:
I think I used a bargin bin shifter knob, some 1/2" round steel rod, a small sledge hammer, a vise, a drill press, a grinder, and a few hours of hard work.
/ My PT-422 mods
Robin OEM engine filter replacement:
This was done to avoid having to purchase expense OEM filters over the web. You should be able to save a few bucks and go to the local tractor supply store and find a Kohler filter to use. I believe this should work on the 18, 22 and 25 hp versions, but the one in the pictures is a PT422. I based the following on an email from forum member wa****a although I did my mine slightly different, but the idea is the same... remove the metal cover from the OEM and use it with a more readily available filter element.
First, separate the paper element from the stock filter metal plate. There will likely be some rubber residue along the edge of the plate, so I just ran a wide blade screw driver along it to lift it up. Some of it would pull away in chunks making it easier. I don't think it has to be perfectly clean, but it needs to make a good seal with the top of the replacement filter. Be careful not to jam the tool into your hand while peeling up the residue, or cut your fingers on the wire mesh surrounding the paper element.
Wa****a suggested I use air filter #47 883 03-s1 for Kohler Command CH18-23 hp and CV17-23 hp engines. I used a slightly different model as seen in the following picture since it was all Tractor Supply Co had yesterday. The other model numbers may or may not be a better fit. I noticed the one I used (4708303) mated with the metal plate well, but was a tight fit onto the carburetor housing. The cost was $12.49 and included a prefilter.
You'll need to push down with enough even pressure to get the filter onto the carb housing without crushing it. This ensures a good seal, and allows the nut to reach the the threads when tightening it all down... but more on that later.
Here's a pic showing the metal plate over the installed filter, along with the prefilter. The nut is screwed on just to show how the metal plate makes a good seal with the new filter.
Since the filter I purchased had a slightly smaller inside diameter, I needed to push the element down onto the carb body with some force to get it to sit lower. Even after doing this, the filter was a bit higher and and wouldn't allow the nut to reach the threads when everything was installed, so I had to remove some material on the bench grinder.
Here's the last pic with the cover in place. The total time to do the mod was about 15 mins. Hope this helps someone else too. :)
/ My PT-422 mods #7
KMA, nice job! I never thought of that. Very good idea.
/ My PT-422 mods #8
I did something similar, but I used a car filter that's about 3 times as tall for about the same price. NAPA 2702. It's for an old Volvo, so it probably won't be in stock. I order them 3 or 4 at a time.
It's a bit larger in diameter than the original, so it has to squeeze down into the base plate. I replaced the stock stud with a longer piece of all-thread. The plastic cover falls quite a bit short of covering the element, so I left it off. I'll come up with another cover one of these days - maybe a big coffee can or something....
/ My PT-422 mods
To stop my PT422 from burning my lawn when I stop for a few seconds or from kicking up ton's of dust when working in dirty areas, I decided to do something simple and cheap since I do not own welding equipment (yet). I picked up a 1 1/2" copper elbow at the hardware store today and drilled a hole through my exhaust tip for a bolt. I added another set screw to keep it from vibrating.
/ My PT-422 mods #10
your improvements are mind candy to those of us that just have to modify our PT's...
I'm considering an improved tilt seat for my retrofit PT2445 slope mower. Any regrets on the one you chose after using it?
/ My PT-422 mods
Actually yes... I've since reverted back to the stock seat and removed the TSC seat from my PT although it did help absorb the bumps. When I first built my home a few years back, there was no grass and my clay soil hardens like a rock. So as I drove around and did work my kidneys took a good pounding. The springer seat helped a ton with that. Unfortunately, it sits you up quite a bit higher such that my wife and son couldn't drive the tractor comfortably. The other issue with the TSC model's design is that it tilted slightly side to side, making it uncomfortable to drive across hills and when using the mini hoe on sloped areas. There were a few other minor annoyances too like it wouldn't stay put in the forward position when opening the engine compartment.
I think a lower profile seat that is more stable but still takes some of the impact out of driving over rough terrain would be a better choice. The TSC served it's purpose and now that my property is coming along it isn't quite as rough to drive on so the stock seat is fine.
Good luck!
BTW I've installed a simple fuel shutoff valve based on the advice found on this forum. I will try to take a few pics and post here when I can.
/ My PT-422 mods
Per the suggests of forum members, added a fuel shutoff valve for when the tractor sits for extended periods of time. Fashioned a simple bracket under the driver side of the fuel tank so it would be easily accessible and not resting against anything hot.
/ My PT-422 mods #14
Nice work on the engine transplant!
Would a Fuel Shutoff valve still be recommended for a new PT 425? I vaguely remember the reason was gas continuing to flow into the carb even after key turns off the tractor ???? Just wondering if its still a problem with the newer engines. I have never smelled gas after parking the PT in the garage for several days.
Patrick
/ My PT-422 mods #15
I had the aforementioned leak happen 1x to my 425. Added a $5 shut off valve and now no worries.
I sometimes forget to shut it off. Even "funnier" is I forget to open it. The 425 will run about 10 sec before sputtering out. It surprises me every time.
The 1x it happened, gas flowed into the carb it also flooded one of the cylinders. I had to pull a plugs and turn it over a few times to void the gas before reinserting plugs. Warning! Gas comes out of the plug whole at warp speed/spray! Put a few shop towels over it to "catch" the discharge.
/ My PT-422 mods
Clumber, I've used the shutoff valve if the tractor sat for relatively extended period of time. An easy example is over winter or maybe if I knew I wasn't going to use it for a week or so. During the summer months I rarely turned it off. Good luck!
/ My PT-422 mods
As a temporary fix to the exhaust kicking up dust and burner grass when stopped, I added a simple copper elbow a few years back. Sometime later I swapped out the exhaust for a modified Robin model, but it wasn't sturdy enough to be mounted outside the tub (it was designed to be bolted directly to the side of the engine). I eventually went back to the PT OEM exhaust, but decided to swap out the copper elbow for a more permanent solution. What I did was take a short piece of angle iron, then cut bend and weld it up to the tip of the muffler. It looks stock and changes the direction of the gas flow enough to avoid my original problems. I finally got around to posting a picture in this thread.
