My Place: a CAT, Mahindra, and Ducks
   / My Place: a CAT, Mahindra, and Ducks
Guess it is time for you to level up your tractor a size or two. :)
Not likely. The Lull was in the shop.
I need to rebuild the two slave cylinders and she will be ready to use again. She can lift 6,000 pounds.
hugs, Brandi
   / My Place: a CAT, Mahindra, and Ducks #612
Your plastic bushing project reminds me of a big patio umbrella a friend of mine had that suffered a pivot failure during a wind event. She got a replacement comped somehow, and I took the old one and fabbed up some metal replacement parts. I did two sets while I was at it; good thing as the replacement suffered the same fate.
Your plastic bushing project reminds me of a big patio umbrella a friend of mine had that suffered a pivot failure during a wind event. She got a replacement comped somehow, and I took the old one and fabbed up some metal replacement parts. I did two sets while I was at it; good thing as the replacement suffered the same fate. View attachment 782033View attachment 782034View attachment 782035
I made some metal parts for my daughter's patio umbrellra a few years ago.
hugs, Brandi
I got the trusses up and the purlins on ready for tin.
I didn't work on the coop Monday, as I was down in the clay pit showing the owner what logs of his were White Oak. He is gonna bring them over for me to saw into more trailer decking along with some large Red Oak logs for me.
I asked about a truck load of clay and he asked..............pickup or dump truck? I said dumptruck and asked how much. He said.......no charge, it will be there tomorrow afternoon!
It is nice having him nearby. They are almost finished digging there, and will turn into about a 10 acre lake. This, below, will be the shallow end. The deep end is about 18-20 feet deep.
hugs, Brandi
Yesterday while adding gearbox oil to the tiller, I accidently let the little tube slip off of the syringe I was using to add oil. The tube was just 4 inches long and just long enough to lodge inside the gearbox. I tried small needlenose pliers to retrieve it, but failed. I had to remove the handle bars and all the belt pulleys for forward and reverse to get to the top of the gearbox. I removed the tube after getting the top off of the gearbox and made a new gasket. 3 hours later ................this is the result.................
Brady tilled the garden while I remove the Mahindra's alternator to get it checked out.
hugs, Brandi
   / My Place: a CAT, Mahindra, and Ducks #619
Might want a taller fence to keep the chickens out of the garden, unless you're not going to let them out to free range. I let mine free range. They keep the bug population down and fertilize the lawn. They still go back in their caged coop at night, and we lock the gate.
Kyle,
The chicken yard will be about 10 times bigger than the garden. Brady says he will allow the chickens in the garden, but only a few at a time. The chicken yard fence was going to surround the garden, but now the garden will be part of the chicken yard fence.
hugs, Brandi
1997 75KW Tow Behind Generator (A55787)
1997 75KW Tow...
Case 1845C (A47477)
Case 1845C (A47477)
2011 Ford Ranger Ext. Cab Pickup Truck (A54814)
2011 Ford Ranger...
2025 Kivel Forks and Frame Mini Skid Steer Attachment (A55787)
2025 Kivel Forks...
20'x20' High End Carport (A53316)
20'x20' High End...
WB Mower (A50120)
WB Mower (A50120)
