My next truck if only it were to be
   / My next truck if only it were to be #41
As the Brits would say, we are talking 'bout trucks built for "townies", not for people that actually work a truck.
True! I had a Mitsubishi L200 crew cab "warrior" model. 2.5L turbo Diesel engine.
It was ok but didn't excel as a work vehicle or private car as it was underpowered for motorway driving, handled terribly and had no where to put shopping etc! As a work vehicle, it would carry 1000kg in the load bed, if you could fit it in!
The lease was for 5 years and ended in May.
I always had a proper work van too, currently a Renault Master - 1560kg payload, 2.5L turbo diesel, quick vehicle, good capacity and a real work horse.
Do you guys in the US not have Ford transits or similar? They're a massively popular work van here, with pickups, flat beds & tippers being very sought after.
The small Transit Scooby is talking about has so far only been available here with a gasoline motor. And, it's small, you'd have a hard time fitting anything longer than about 4' inside if you have a bulkhead.
The Daimler Sprinter pretty much has the market to itself, diesel wise here. Bad parts logistics for commercial use though - a 500K km Sprinter came into my buddy's shop, spewing fuel. Can't remember it's designation, but it was the fuel pump in front, towards the top of the block.
A new pump was crazy money, you had to send in the core, and PRE-pay the huge $. That wasn't the worst part - the turnaround was 6+ weeks - Daimler Canada would just send them out for rebuild in batches, no pumps were stocked !
The problem was that most of the mounting screws had vibrated loose on the main backing plate on the pump. Replaced what O rings could be easily changed, loctited the screws back in place, and prayed. Fortunately for the customer, the repair worked.
Otherwise, the truck would have been down for a ridiculous amount of time.
I'm also hearing about problems on the NV diesels that Chrysler is using in Jeeps and Cherokees here. Bearings etc.... that shouldn't be going at this life-stage. Too many stories like these shore up the argument that "Diesels are hard to repair, and very expensive" - personally, I don't want to see these stories gaining any more momentum, even as Urban Legends.
There is a fantastic range of diesel light-vehicles available in Europe, commercial and other wise. I'd like to see more of them here. Some manufacturers we don't have at all (Renault) at this time, but just GM and Ford alone have many offerings.
I'm in Canada, but still... the biggest impediment to broader use of diesel is the EPA. Plenty of rants on here already on that subject, mine included....
Enjoy the broad diesel selection that you have, we can't at the moment.
Rgds, D
   / My next truck if only it were to be #42
One truck that will be missing for at least a couple of years is the Honda Ridgeline. I have read they are going to stop production for 2 model years to redesign the truck. It is supposed to stop next September and start again in 2016.
   / My next truck if only it were to be #43
No real loss there. All they are doing right now is clogging dealer lots. They basically have to give the thing away . Maybe they should put a bag over its ugly head to try to sell more? lol.
   / My next truck if only it were to be #44
Well, if they actually made good deals on them, they would look better ;)
   / My next truck if only it were to be #45
The Ridgeline is a very HEAVY vehicle. It's about 4,500 #. That's 1,000 # heavier than the equivalent Tacoma. Even the Tacoma has become a heavy weight. Our 2005 extracab is 3,500 # compared to 3,000 # of our 1996 Tacoma. Wish they'd buy VW's TDI and slap it into the old Tacoma body. They could eliminate the rear differential then. Probably would get 50 mpg and with same 140 hp as in the 1996 4 cylinder that had a lot more GO than the 2.7 liter one in our 2005.
2017 Freightliner Cascadia 125 Single Axle Sleeper Cab Truck Tractor (A50323)
2017 Freightliner...
2020 Takeuchi TL10V2 (A47384)
2020 Takeuchi...
2022 BANDIT 2550TK STUMP GRINDER (A51242)
2022 BANDIT 2550TK...
2018 GENIE GTH-636 TELESCOPIC FORKLIFT (A51242)
2018 GENIE GTH-636...
UNUSED CFG Industrial H15R Mini Excavator (A47384)
UNUSED CFG...
(9) 2 PLUG VALVES 1502 IRON (A52472)
(9) 2 PLUG VALVES...
