Rotary Cutter My new project/Bush hog
   / My new project/Bush hog #11
AaronS, what were you doing in Oconee? I live in Oconee. Beautiful area I gladly call home.
Yes beautiful to say the least. My wife and I were looking at homes around Lake Keowee and the surrounding area. Thinking of a possible move one of these days.
   / My new project/Bush hog #12
That looks like my kind of project. Heat and beat then paint to match. The previous owner must have run it with the skids dragging all the time to wear them completely away. I would likely cut off the thin sheet metal sides and replace with a piece of channel iron for some side wall strength.
   / My new project/Bush hog #13
I got all excited over a 6' cutter priced at $399 that looked pretty new, until I saw the rotary swirl in the top deck. At least yours doesn't seem to have that problem, and maybe yours still has a USA made gearbox?
I did not weld deeper skirts I just welded some angle iron onto the sides. It will ground out easier..but I really didnt notice it untll I welded one skid on and I just left it as is. I could of cheated the angle iron down a bit but I didnt. I didnt even heat it. I just patched it up and welded it back up with patches and called it good. It does have a minor swirl marks but it was cause the sides had no stability I believe. It looks like the original al box as well. I only painted my work as I may do more to it?? Its not perfect but serviceable.
2006 FREIGHTLINER CST120 (INOPERABLE) (A55745)
2006 FREIGHTLINER...
2017 Toro Z-Master 7000 Series 70in Zero Turn Commercial Mower (A55787)
2017 Toro Z-Master...
2018  FREIGHTLINER M2 26FT NON CDL BOX TRUCK (A52576)
2018 FREIGHTLINER...
2004 DRAGON 150 BBL ALUMINUM VACUUM TRAILER (A53843)
2004 DRAGON 150...
1987 Landall 48ft 35 Ton Hydraulic Slide Axle T/A Drop Deck Trailer (A55852)
1987 Landall 48ft...
