My New Machine???
/ My New Machine???
LarryRB said:
not related to this thread, however, Doug was at the house the other day asking about my semi home made cab. Here it is and trailered
That's a really great set-up Larry... and I know you've even got heat in that cab. :)
You should post that in the "customization" section.
Dougster
/ My New Machine??? #262
bindian said:
Brian,
Yes, there are another kind. RED, nasty metal trailer ramps. :D
hugs, Brandi
Dougster said:
A little pressure-treated dimension lumber under the ramp ends and supports when deployed
OK you guys, you have painted them red or used wood while using these nasty metal ramps, buuuut they are still nasty metal ramps. So, I am back to "are there any other kind" ? Heck, I even had a set of chrome plated ramps for my buggy trailer back when I went to the desert. But that didn't change what they were. Nasty.:p ;)
/ My New Machine??? #263
bindian said:
Brian,
Civesnedfield,
My grouser pads have two holes approx 5/6-3/4 inch in diameter. I am thinking about welding pins on my modifed "mudder" plates that can be attached with a quick pin through the existing holes. :cool:
hugs, Brandi
I see that you are alreay on top of it. :cool:
/ My New Machine???
Well, okay... so they are nasty. :rolleyes: There is only one kind. It does make you wonder, however, why they don't make them with some sort of flat feet that would not mar the pavement so badly. I've thought about adding stabilizers to my equipment trailer (like on my dump trailer) to keep the trailer dead level and help reduce the pavement marring effect... but all that nonsense just keeps adding weight to my already marginal 10K equipment trailer.
Wood is cheap, light, sits in the truck bed... and works just as well. :)
Dougster
/ My New Machine??? #265
Dougster
Ah now we get to the root of the whole issue :D
/ My New Machine???
Oh, like it's a BIG SECRET that I am dirt poor!!! :rolleyes:
Dougster
/ My New Machine???
Well, it turns out that half the parts I received in this "kit" aren't even remotely relevant to the hydraulic cylinder installation. It appears that someone at the Bradco factory added the wrong installation hardware to this crate. :rolleyes: Now I am wondering if I got all the stuff that should have been in there.
Thumb Update: Looks like I got everything relating to the Bradco thumb hydraulics that I actually paid for... plus some miscellaneous, useless parts that have nothing whatsoever to do with the thumb. :confused: Very strange. So much for my earlier statement that suggested I received a far more complete kit than anticipated. :rolleyes:
BTW, I measured the new thumb hydraulic cylinder and it is definitely a 2.5" ID cylinder... not a 2.75" cylinder as I had always suspected. Now I am really confused about the "80% of bucket force" statement by Bradco that can supposedly be applied by the thumb using this cylinder. Better check my calculations again, but I don't think that computes! :eek:
Lastly, the low and more exposed locations of the two cylinder connections are apparently explained by Bradco wishing to avoid interference with the large stick-mounted thumb bracket without having to use top or bottom mounted connections. I suppose this makes sense... but I'll have to be extra careful when digging deep with the hydraulic cylinder installed.
Dougster
/ My New Machine??? #268
Larry,
That looks cute and cozy. :) Is that BH controls I see hanging outside your cab? :confused: I could put one on the Big Red Beast, but I don't have an air conditioner for it. :rolleyes:
hugs, Brandi
/ My New Machine??? #269
Dougster said:
Thumb Update:
Dougster
Dougster,
The way Bradco runs the hard line for the bucket cylinder, I find that answer hard to believe. :rolleyes: Guess that is Engineer speak for..........I don't want to take the time to design a nice tight hyd. installation. :eek:
hugs, Brandi
/ My New Machine??? #270
bindian said:
Larry,
hugs, Brandi
THis is a Kubota L48, so I don't have to dismount tractor and mount hoe like I did with my Mahindra. Just spin the seat. A slot was cut into the rear fabric in which the hoe controls fit up through. With some days here well below zero ambient and closer to 30 below wind chill, that slot isn't even a consideration. One of the best moves I made. Curtiss is 25 miles from me and that is what I wanted, However, I hate their attitude. I called several times within a 4 month period and was always told, when we feel like making TLB cab parts for the 48, then we will. I live along side a reservoir and with bare trees and high winds coming off the water, something had to be done..I felt forced to get someone to help and that is what you see now.
/ My New Machine???
bindian said:
Dougster, The way Bradco runs the hard line for the bucket cylinder, I find that answer hard to believe. :rolleyes: Guess that is Engineer speak for..........I don't want to take the time to design a nice tight hyd. installation. :eek:
hugs, Brandi
Who knows? :confused: Maybe it is the best option... maybe not. :rolleyes: Doesn't make a whole lot of difference now as the whole dang thing is sitting here ready to install as soon as I gather up a few last parts and order up some hose and hose ends.
But I also gotta tell you that the full kit looks like a bear to install from the set of installation instructions I got with the kit. So glad I am not going that "full install" route. If you do go that way, I suggest letting your dealer install it. If anyone could do it, you could (with your aircraft experience)... but if you can work a little "OT" and pay the dealer, I say do it! ;)
Dougster
/ My New Machine??? #272
Dougster
What?:eek: Let them have all my fun???:p How is the cylinder installation coming? You have been quiet. Hope the foot is better. :)
hugs, Brandi
/ My New Machine???
hugs, Brandi
The foot is well enough to be working again... :eek: ...which is exactly what I have been doing. This is probably why you feel I have been quiet... :D ...and it's also partly why the cylinder is not yet installed. The main issue is that I am waiting for hose and fittings from DHH and bulkhead brackets and other miscellaneous hardware from Bradco. Given the wait for parts and the little unexpected backlog I've suddenly got for September, the new cylinder may not get installed before the end of the month.
Dougster
2006 INTERNATIONAL  4300 4X2 S/A SPREADER TRUCK (A66091)
2006 INTERNATIONAL...
ALLMAND MAXI-LITE II V LIGHT PLANT (A68842)
ALLMAND MAXI-LITE...
1987 Polar 307 SS 3 Comp SS Insulated T/A Chemical Tanker Trailer (A68183)
1987 Polar 307 SS...
2014 HIPOWER 310 Generator (A67714)
2014 HIPOWER 310...
2019 Cadillac XTS Stretch Limousine for Sale, S and S Coachbuilders, 70IN, 7866 Miles (A63689)
2019 Cadillac XTS...
2016 FREIGHTLINER CORONADO 122 SD (A67714)
2016 FREIGHTLINER...
