My new L3400
/ My new L3400 #1
johnw
New Hampshire
Kubota L3400
Well, here's my new toy. Of course don't let my wife know that. As far as she knows this is a serious piece of equipment, absolutely necessary for moving snow, loam and big rocks!!! It looks so good I have moved my car out of the barn and for now am parking the tractor inside. The camry is now parked the field beside the Chevy PU.
/ My new L3400 #2
Looks great - and yes, the tractor was the most expensive vehicle we have now - so it also moved the car out and occupied our garage as well. /forums/images/graemlins/smirk.gif
/ My new L3400 #3
Beautiful Rig. Came very close to getting the L3400 myself and look forward to posts from you describing how you like it.
Mike
/ My new L3400 #4
That's a nice looking machine you have there. /forums/images/graemlins/cool.gif
/ My new L3400
Yes, I plan to do a lot of "work" with it this weekend. And will get some more photos to post. I have put some pretty good ruts in our lawn already so I have to be careful where I take it. Those AG tires really chew things up.
/ My new L3400 #6
It's a beauty..such a nice color of orange too. By the way, did you get a tooth bar and did you find out the actual weight of that toy...er..I mean serious piece of equipment? I know you had concerns about those things. Congrats on the new tractor. I know you will enjoy it.
/ My new L3400
Hi Mike, yes I did find out the weight. 2,600 for the tractor (2,568 without fluids) 895 for the FEL and 400 for the loaded rear tires so I'm very close to 4,000 lbs. Have not purchased the tooth bar yet but I definately plan to. It has not been that easy digging up those juniper bushes with just the cutting edge on the bucket. Unless I put a lot of downward pressure on the bucket, which digs up a big chunk of field, the bucket tends to flatten out the bush and then slide along the roots. So I am sure the teeth can get in-between the roots and tear the bush out. I will have to check those posts again to see where is the best place to purchase one. Unless you remember. I forget who posted those photos but it looked like a breeze to install and the bar looked pretty rugged. Here a picture of about 25 barrels I dug out of the ground that it would have been handy to have the tooth bar. These are 1/2 of 35-55 gal drums set in the ground around plants way back when my land was a working farm.
/ My new L3400 #8
Here is my tooth bar, which I just installed yesterday. Plan on using it today or tomorrow. Got it from http://markhamwelding.com/. It is a nice, heavy, sturdy bar and they custom make the bar to fit your bucket. My bar cost $215 plus shipping, which was $70 (freight collect) and I picked it up at the trucking terminal. I had them put an extra tooth on for my needs, but I think the standard number is 7 teeth. From the time I ordered till the time I had it installed was only 5 days. Measure the inside width of your bucket, 8" back from the front cutting edge. It was easy to install, and can be removed in a matter of minutes. Lots of info in the several post around TBN...good luck.
/ My new L3400 #9
very nice looking tractor, and as far as the ags tearing things up, so will any tire in sort condition or sharp turns especially in 4wd. i have industrials and they will do the same thing on occasion
/ My new L3400
Thanks Frank that is good to know. I was kind of kicking myself for not going with the industrial tires. But now i believe you are correct, a 4,000 lb tractor in soft soil is going to do damage no matter the tire.
/ My new L3400 #11
John, got the exact same as yours Weds. I was a little intimidated for a couple minutes getting used to the controls. Spent Thurs mowing and half Fri. I went slow as there are a lot of stumps, most low, but a few higher ones in the weeds. I got about 7 out of 10 acres chopped down and it looks great. I broke a shear pin on a stump but that was easy to fix. I accidently pushed over a medium sized tree not looking where I was going. Tough tractor, just went through and over it like it wasn't there. I hope you enjoy yours like I am enjoying mine. I can reccommend it to anyone.
/ My new L3400
Hi Dennis, hope you have a ball with your L3400. I have 5 hours on mine so far. This weekend I purchased 4 high bush blueberry bushes from a farm stand that is goind out of business. These things are huge, 7 feet tall and with the root ball they weighed close to 300 LBs. They loaded them into my truck with a large backhoe. Could only take 2 at a time. The Kubota came in real handy for digging the new holes and for getting the bushes out of the back of my pickup. I should have taken some pictures. I can't wait to get my bush hog.
/ My new L3400 #13
I will second bigmike on the toothbar suggestion, they are tough to beat, and as he said easy to install and remove. Got mine in ONE day after ordering it, and like mike had to pick it up at the terminal, but hey it is five minutes from work........and on my way anyway.
Great bars, and it will improve the bucket for digging and tearing out much more than bucket alone.
Nice rig, and my cars sit outside also
/ My new L3400
Mike, just ordered my toothbar from Markhamwelding. $259 delivered for a 5ft bar. Should be here Tuesday.
/ My new L3400 #15
Great looking tractor! I am sure that it will do a lot of cool stuff. (I mean hard work!)
Donald B.
2018 INTERNATIONAL LT DAY CAB TRUCK TRACTOR (A67147)
2018 INTERNATIONAL...
Murray Explorer Go Cart (A65640)
Murray Explorer Go...
INOP/NON-RUNNING 2005 Kenworth W900 Sleeper Truck, VIN # 1XKWDB9X55J074790 (A65563)
INOP/NON-RUNNING...
New 5/16" G80 Double Chain Sling (A62679)
New 5/16" G80...
New, Landhonor Skid Steer Pallet Forks  (A62679)
New, Landhonor...
Skid Steer Blank Plate (A65640)
Skid Steer Blank...
