My new B2320 is dead! Help!
   / My new B2320 is dead! Help! #1
maximus1277
Manchester CT
2010 KUBOTA B2320, 2010 KIOTI CK27, Kubota L3940,JD110 TLB
This is both embarrassing and annoying.... I pulled up to the front of my house to move a bush damaged by heavy snow last winter. Tractor warmed up and ran fine. I just shut it off for 5 minutes while I was digging out the damaged plant with a shovel. I got back on, and the tractor would not start.... the battery is fine, all the lights come on, but the starter won't turn over. I checked all the fuses and I checked several times to make sure the tractor is not in gear (this is a non HST model). Gear models start in neutral when not in the seat. I even bypassed two switches under the seat (one is activated when you sit down - the other, I don't know yet what it´s for) to get it going but no luck! It is approximately 50 degrees outside and the tractor has plenty of fluids. Help!
   / My new B2320 is dead! Help! #2
95% of the time, its one of the safety switches. Put the ones under the seat back the way they were. Then check to make sure all of the levers are where they need to be to start...... range in 'N" , PTO off, etc. If that doesn't do it, try lightly tapping both front and rear hydrostat pedals to ensure it goes back to center.
   / My new B2320 is dead! Help! #3
Check and make sure the pto lever isn't engaged.
Thanks ....I checked every switch except the PTO lever.... It was engaged! That's a first for me.... Rookie mistake. Thanks for the suggestions.
   / My new B2320 is dead! Help! #6
Isn't it nice to discover it's only operator error and not
a **** electrical nightmare somewhere in the harness/switches :)
How many of us have not been able to remove the key from an
ignition because we've stopped the SUV whilst it was still
in drive ? :laughing:
   / My new B2320 is dead! Help! #7
sounds like the big q is how did you engage your pto with out knowing it.
The most embarrasing thing is that the tractor was partially blocking the garage..... it would be real problem if my wife was unable to get to work because of this. Interstingly, my curious neighbor just happen to witness this unfortunate breakdown and he was sure to make a comment or two about the quality of today's tractors....
   / My new B2320 is dead! Help! #9
I can only speak for myself, but I can be a klutz. I hit the FEL lever with my knee when looking backward at the rear blade. Arrrrrgh! You hear the sound of your bucket dragging and know you've done it again.
I snag my sleeves, pants, jackets on levers and knobs.
Some of this stuff is indeed just our fault. Some of it is not placed in the greatest places, frankly, and add to that, the modern CUT has a heck of lot of levers. Add to that the **** safety switches connected to everything and well.... there's no more "big q". :D
   / My new B2320 is dead! Help! #10
you just reminded me of something i did a good while back.i was out shredding while my neice an nphew sprayed some torn stobbs.an somehow a torn bush hitt my hood latch an up popped the hood.well i let the loader down to close the hood.an i took off an forgot to raise the loader for a minute.i was like i cant beleive i just did that.
CASE ROOT PLOW (A58214)
CASE ROOT PLOW...
2004 Pierce Tilt Crew Cab Enforcer Fire Truck (A55853)
2004 Pierce Tilt...
(1) HD 24ft Free Standing Corral Panel (A57453)
(1) HD 24ft Free...
(1) HD 20ft Free Standing Corral Panel with Feed Bunk (A57453)
(1) HD 20ft Free...
Greenworks Commercial 82V Utility Vehicle 500 CAMO Model: U500SC - DEMO UNIT (A56436)
Greenworks...
2024 CATERPILLAR 255 SKID STEER (A60429)
2024 CATERPILLAR...
