My Mahindra 3215 has very little power
   / My Mahindra 3215 has very little power #1
Jimneaf
My Mahindra 3215 shuttle shift has very little power. Just about any resistance causes the wheels to stop. It doesn’t appear that the clutch is slipping. Anyone have any suggestions? I replaced the fuel filter and cleaned the air filter. The fluid levels are fine!
   / My Mahindra 3215 has very little power #2
:welcome:
To the TBN forum Jim.
What are the rpms when it stops? Does it start with normal rpms and them drop?
   / My Mahindra 3215 has very little power #3
Check the parking brake.Done that before.
   / My Mahindra 3215 has very little power #4
:welcome:
Welcome to the forum!
I'm going to move this thread over to our Mahindra section.
Thanks! The rpm´s do not drop under a load. Would seem that the clutch is slipping, but there is no sound to indicate that?
   / My Mahindra 3215 has very little power #6
Never heard a slipping clutch make any sound. For a gear drive, only one thing will allow the engine to maintain RPM but no forward motion. You need to get that clutch adjusted NOW before the slipping burns it up. Hopefully it is only an adjustment needed and not a new clutch plate. With a shuttle shift there is also a hydraulic clutch action that briefly depresses the clutch plate when the shuttle shift lever is moved, it could be that the hydraulic clutch is not disengaging correctly also. A trip to the dealer is recommended for this.
Ok, thanks!
CATERPILLAR 308E2 CR EXCAVATOR (A50458)
CATERPILLAR 308E2...
2012 Mack CXU613 Day Cab T/A Wet Kit Truck Tractor (A50323)
2012 Mack CXU613...
2008 BMW 535xi AWD Sedan (A50324)
2008 BMW 535xi AWD...
2005 IH 7600 t/a Dump Truck (A52384)
2005 IH 7600 t/a...
2018 GMC Sierra 2500 4x4 Crew Cab Pickup Truck (A50323)
2018 GMC Sierra...
2008 John Deere 608C combine head (A50657)
2008 John Deere...
