My Mahindra 3215 has very little power
   / My Mahindra 3215 has very little power #1
Jimneaf
My Mahindra 3215 shuttle shift has very little power. Just about any resistance causes the wheels to stop. It doesn’t appear that the clutch is slipping. Anyone have any suggestions? I replaced the fuel filter and cleaned the air filter. The fluid levels are fine!
   / My Mahindra 3215 has very little power #2
:welcome:
To the TBN forum Jim.
What are the rpms when it stops? Does it start with normal rpms and them drop?
   / My Mahindra 3215 has very little power #3
Check the parking brake.Done that before.
   / My Mahindra 3215 has very little power #4
:welcome:
Welcome to the forum!
I'm going to move this thread over to our Mahindra section.
Thanks! The rpm´s do not drop under a load. Would seem that the clutch is slipping, but there is no sound to indicate that?
   / My Mahindra 3215 has very little power #6
Never heard a slipping clutch make any sound. For a gear drive, only one thing will allow the engine to maintain RPM but no forward motion. You need to get that clutch adjusted NOW before the slipping burns it up. Hopefully it is only an adjustment needed and not a new clutch plate. With a shuttle shift there is also a hydraulic clutch action that briefly depresses the clutch plate when the shuttle shift lever is moved, it could be that the hydraulic clutch is not disengaging correctly also. A trip to the dealer is recommended for this.
Ok, thanks!
2008 FORD F-750XL SUPER DUTY ASPHALT DISTRIBUTOR T (A51243)
2008 FORD F-750XL...
2007 JOHN DEERE 624J WHEEL LOADER (A51406)
2007 JOHN DEERE...
PLEASE CHECK BACK!!! ITEMS BEING ADDED DAILY!!!! (A50775)
PLEASE CHECK...
2008 MACK GRANITE HOT OIL (A50854)
2008 MACK GRANITE...
Kinze 840 Grain Cart (A50514)
Kinze 840 Grain...
SELLICK S80J4E-4PS ROUGH TERRAIN FORKLIFT (A51242)
SELLICK S80J4E-4PS...
