My loader won't crack
   / My loader won't crack #1
fcamillieri
Chester, NH
CK20HST
I have a CK20 with the older, 2006, loader and it hasn't cracked. I've been using it pretty hard for 150 hours and doing what my farmer friend says shouldn't be done. He keeps telling me that the loader is on the front and the digger is on the back. I've even used the corner of the loader to dig up some pretty large rocks. Do I just have an exceptional loader?
http://stonemachine.com/frank/tractor/Kiote-1.JPG
http://stonemachine.com/frank/tractor/Kiote-2.JPG
http://stonemachine.com/frank/tractor/Kiote-3.JPG
http://stonemachine.com/frank/tractor/Kiote-5.JPG
   / My loader won't crack #2
Those look to be some heavy loads, I don't think I would have thought about putting something that big on my KL130 loader. Can we get a better shot of the torque tube on your loader?
I don't have any pictures of the torque tube but it is the old stye and doesn't have the reinforcement installed.
Frank
   / My loader won't crack #4
Just a suggestion but if you wish to lift that type of load on a regular basis perhaps you should make provisions so the load can't come back and sit on your lap or on the loader rams!:D :D :D
My B7100 would not lift that load.:( :( :(
I cheated a bit. The loader wouldn't lift it so I ran it up against a snowbank for some help. I kept it low enough so there was no danger of it coming over the top. The largest one was probably close to 1000 lbs plus it was hung out over the front of the bucket.
   / My loader won't crack #6
fcamillieri said:
I have a CK20 with the older, 2006, loader and it hasn't cracked. I've been using it pretty hard for 150 hours and doing what my farmer friend says shouldn't be done. He keeps telling me that the loader is on the front and the digger is on the back. I've even used the corner of the loader to dig up some pretty large rocks. Do I just have an exceptional loader? (fcamillieri)
Awwwwww shucks! My CK20 can do that too. I'll try lifting the same block of wood only bigger. look here:
These darn CK20 drivers around here, one tells a whopper and the next one swears to it.
Rimshot (all in good fun)
   / My loader won't crack #7
:eek: :eek: OMG :eek: :eek:
   / My loader won't crack #8
What did you do, RIMSHOT, photoshop the backhoe out of your shot?
I can't see how your tractor does not tip forward with no ballast. I thought
balsa wood was a tropical tree.
   / My loader won't crack #9
Rimshot, why would you need a tractor like that just to move kindling around ? :)
Hey Rimshot
I want to know how you got my log to Michigan! I want it back!
Frank
2002 Sterling M7500 Acterra Lift-All LA04C51-15 Insulated Forestry Bucket Truck (A50323)
2002 Sterling...
2016 Ford Explorer AWD SUV (A50324)
2016 Ford Explorer...
2013 PETERBILT 367 (A52472)
2013 PETERBILT 367...
2012 Ford F-150 Pickup Truck (A50323)
2012 Ford F-150...
John Deere 1790 Planter (A50514)
John Deere 1790...
2006 Poly-Coat Tanker Trailer (A50774)
2006 Poly-Coat...
