Tires My lesson learned on loaded tires
   / My lesson learned on loaded tires
</font><font color="blue" class="small">( While the manual mentions that weights are not available for turfs, it doesn't mention anything about not using them. )</font>
That's what mine says too. Somewhere in my head that translated to not being able to mount them to the rims. The 12LA manual suggests 75% full of 5lb solution of CaCl for the turfs, giving 200 lbs per tire. I guess 160 lbs of washer fluid (at approx 8 lbs per gallon) would also bring me to about 75%. Anyway, it all started with a pin hole in the sidewall prompting me to get tubes installed and then take the next step to getting them filled since I already had them off for service and had realized the tractor was lighter in the rear than I expected. No leaks - anchored to the ground = happy camper /forums/images/graemlins/laugh.gif
Brad
   / My lesson learned on loaded tires #12
Brad & Junkman -
75% filled probably makes sense. I would bet the CG of them and Iron would be nearly the same with that amount.
Thanks,
Floyd
   / My lesson learned on loaded tires #13
properly filled tires at 75% liquid to air has 16% more of the weigh below the axle center line. How much that difference equates out to the handling characteristics, I can't say, but probably not very much different.
   / My lesson learned on loaded tires #14
Cool - I just keep on learning - You guys just keep on teaching /forums/images/graemlins/smile.gif
fwc
   / My lesson learned on loaded tires #15
Lots of CC fluid used by us Ag guys up here in the midwest. /forums/images/graemlins/smile.gif Probably 1/3 of the ag tractors are fluid filled in my area. Not the big 4wd models. But anything that's a utility. Finally got my NH 1720 filled last week, had a flat on another tractor so the service guy was out. Sure makes a difference with 600lbs in back, down low! One of my bigger tracotrs has fluid in all 4, must be several 1000 lbs of weight.
--->Paul
   / My lesson learned on loaded tires #16
Some of you guys are going to get real good at fixing those flat tires that you keep getting.
I have seen some pictures here at the TBN site of monster filled tires on trailers again flat because of a nail or the like. Normally most any tractor tire goes flat where you least expect it, and at the furthest point from the house. /forums/images/graemlins/shocked.gif
For my money I still like the concept of cast iron on the rims and Slime (or something similar) in the tires to keep them from going flat.
That way you spend a lot more time driving the tractor than working on it. But then again you do have the choice.
2008 CAT D4K XL (A58214)
2008 CAT D4K XL...
2011 INTERNATIONAL WORKSTAR 7400 SBA 6X4 DUMP TRK (A52706)
2011 INTERNATIONAL...
SKID STEER ATTACHMENT MULCHER (A58214)
SKID STEER...
Sedan (A59231)
Sedan (A59231)
8ft Flatbed Truck Body with Axle (A55851)
8ft Flatbed Truck...
2021 Ver-Mac PCMS-3812 Solar S/A Towable Trailer Message Board (A55973)
2021 Ver-Mac...
