Rear Finish Mower My latest craigslist acqusition!
   / My latest craigslist acqusition! #1
kebo
Elite Member
Lexington, SC
2001 John Deere 790 4x4, bar tires
Just picked up this Sitrex 5ft finish mower today, pics are it sitting on my little 10ft trailer right after I got back to the house. Looks to be decent shape, no major bends/breaks/or welding and everything seems to be there. Didn't get to see or hear it run due to that fact that the man's tractor wasn't running. He had been using it with a gray market tractor (Shibaura I think) and he was having to rewire the ignition key switch for some reason. I could tell that by rocking the PTO shaft back forth it would move the blades so I think it's all working. Did not appear to be any leaks from the gear box either. He was asking $500, the lowest I could get him down was $470. Had to do something after last summer, the heavy rains kept the grass growing so fast that my parents Craftsman mower (21hp) with a 42" deck was just struggling cutting it all summer long. This should do the trick!! :thumbsup:
   / My latest craigslist acqusition! #3
Sitrex is a very good line. Give her a good going over, and get to mowin...
   / My latest craigslist acqusition! #4
good for you i also have bought some good items on there.
   / My latest craigslist acqusition! #5
Looks very straight forward! Should last for years!
   / My latest craigslist acqusition! #6
I have a larger model of your mower, bought used and it works great. If you have uneven ground, with a lot of flexing between the tractor and mower, I would suggest turning the top link attach bracket 180 degrees to increase the amount of free play available. I drained the gearbox by removing the large "C" bracket the grearbox is attached to, turning it over a pan to drain. Of course, the appropriate color paint was applied. Biggest issue I had was removing the blades, as they had never been removed before. Luckily, there is room for an open end wrench above the blade on the spindle which can be lodged against the under deck baffling and with a 48" breaker bar, they were loosened. When looking for parts, include GEORGIA EQUIPMENT COMPANY in your seach, good service and reasonable prices.
   / My latest craigslist acqusition! #8
I had one, worked great. I never hooked up the top link when mowing, only to load it or unload it on the trailer. That way the mower follows the ground contour better. Good luck...
2007 GMC C8500 Altec DM47 47ft Digger Derrick Truck (A55852)
2007 GMC C8500...
2013 FREIGHTLINER CASCADIA (A55745)
2013 FREIGHTLINER...
AIR HOSES & BEAD SETTER (A55745)
AIR HOSES & BEAD...
2018 Ford Fusion Hybird Sedan (A53424)
2018 Ford Fusion...
6-NEW ALTERNATORS (A55745)
6-NEW ALTERNATORS...
2018 International DuraStar 4300 26FT Box Truck (A55852)
2018 International...
