My Iseki Bolens cab project
   / My Iseki Bolens cab project #1
amanda11270
Pennsylvania
Bolens Iseki H1502
I am new to this forum, greetings all. I am in the process of building/designing my own cab. I thought I would post pics of my progress, I plan on adding plexiglass next and a sheet metal roof. This cab is gonna be my sanctuary for the use of my snowblower or plow, I havent decided which to purchase yet, it may be based on which I can find actually. I did post these pictures on another post, but thought I would make my own post for it also.
   / My Iseki Bolens cab project #2
:welcome: to TBN! glad to have you aboard! That cab is lookin pretty darn good. :thumbsup::) Are you using a front mount snow blower/ or plow or a 3 point one? With the 3 point ones, there are many readily available but are more costly over the angle blade (plow). Im not sure where you could get a front mount snow blower or blade for your machine. I use a Montana angle blade with my added gauge wheels. Does a great job for grading and this is the first winter I will get to use my gauge wheels in the snow, one of the main reasons i added the gauge wheels. Gauge wheels wont scrape the gravel off the driveway when I plow the snow so it wont make a big mess after all the snow melts.
I am looking for either a plow or blower really, but I would prefer it be front mounted.
   / My Iseki Bolens cab project #4
hmm, with the front plow and or snow blower, it will take some research on locating one. Have you considered fabricating a plow with hydraulic lift and possibly angle?
Yes, im a pretty good fabricator of parts, making other brands fit etc. So that is a possibility.
   / My Iseki Bolens cab project #6
Here's a picture of my montana angle balde. yes it is 3 point, but with the gauge wheels, it will be graet in the snow this winter. The wheels can pivot and be put in a strait position for reversing the blade or adding weights. Having this on in reverse pushing snow would be graet and the wheels are adjustable through the toplink on the tractor's 3 point hitch. I have done some dirt work with this pushing loose dirt in reverse and it did an excelent job. And being a blade, you can not only use it in the snow, but for grading driveways, dirt work, ditching, etc. Great implement to have around.:thumbsup::) Is your tractor 2 or 4wd?
Mine is a 2WD, and im leaning more towards a front mounted plow/blower if I have a choice.
   / My Iseki Bolens cab project #8
I've just posted a whole bunch of new updated pic's includin' the rear hydraulic cut steel lines and the old under belly mower mount I used to connect the "A" frame to the tractor which fit perfectly (these are just below this post of yours)
I bought a 48"( 4') ATV snowblade these blades are available 48" and 60" size...the "A" frame ( is not included ) can be adapted to mount under the G-174 or G-152 BOLEN ISEKI...I used my old MMM brackets that came with the tractor I modified them to install the "A" frame...the original ATV brackets won't work and besides that.. they are a way too costly
I already had installed a 1/2" plate approx 2 years ago to which I mounted the boom with the chain to install the lift cylinder/ram...is this what your lookin' to install on your BOLENS ?....if you need more info and pic's I have plenty since I first started my project approx 2 months ago...I had a lot of changes to do..once I had to start all over...check em out.....take care Ampa <>
   / My Iseki Bolens cab project #9
Ampa's plow is really nice. Very good example on what to look for. :thumbsup::)
Ampa's plow is a nice setup, I found this forum searching on the internet for ways to add live hydraulics to my Bolens, and it was Ampa's thread I found. His threads and Q and A have helped me understand whats involved. I think it would be cool to be able to angle the plow left to right from the drivers seat.
2018 Nissan Titan Pickup Truck, VIN # 1N6AA1E57JN515039 (A51572)
2018 Nissan Titan...
New Power Line 400 Plastic 3pt. Spin Spreader (A50774)
New Power Line 400...
2025 CFG Industrial TK35R Mini Track Loader Skid Steer (A50322)
2025 CFG...
2014 Kia Sorento SUV (A50324)
2014 Kia Sorento...
