My (hopefully) Modern Shop Build
   / My (hopefully) Modern Shop Build #51
I am super intrigued if a mini split can manage my building without killing my checking account in terms of operational costs. Thoughts?
I have a Mitsubishi mini split in our home-as far as I can tell the added electrical load has been less than $10/month for the most part of course it will depend on your per kwh cost- out here they are pretty low. I know it’ll cost me much less from a heating perspective when compared to propane.
   / My (hopefully) Modern Shop Build #52
I am a big fan of Mini Splits. I added one to handle the heating/COOLING load for my attic conversion office space. Barely noticed a change in the electric bill.
So today I am hoping to have my plans finally in hand so I can go get my permit (which we have been warned is a minimum of 6 weeks). So I took the 9 hours of flying time I had coming back from Morrocco and decided to whip up a game plan for my shop.
A bunch of notes.... It s a dream draft. I can't afford a lot of what is in the picture but things like the car lift I need to plan for in the future. It isn't very big at the end of the day (no shop is I guess). so want to be smart about placing things. I am still new at this graphics program so excuse the glitches.
I am not sure the stairs are correct. I think they are not (as floor to floor is 11 feet (10 ft ceilings on the wood shop). If that is thecase I may be kinda screwed upstairs. My window positions are locked so going to to have to get creative. Oh, yes, there are two 8 foot doors upstairs and downstairs into each respective room.
   / My (hopefully) Modern Shop Build #54
whoever drew the plans for you should have the stairs figured out with the riser/tread dimensions on the plans.....thats just basic architectural information required for a permit and around here the plans will be rejected if the stair info is not on the plans......so unless you want to wait 6 weeks to find out the plans are rejected and need to be resubmitted and then have to wait another 6 weeks make sure the stairs work and all the info is on the plans.......the local building codes will have what the max riser/treads can be so again whoever drew the plans should know that info......there was a push to make 7"/11" the standard but there was a lot of backlash from the residential community so I don't think it ever took hold and it was left to the individual codes to determine based on use.......Jack
   / My (hopefully) Modern Shop Build #55
Suggest that you turn your two post lift 90 degrees to the right, with the nose of the vehicle pointing toward the corner of the room. Better use of space?
2012 Volvo A40F Articulated Truck Cab (A54865)
2012 Volvo A40F...
2025 JOHN DEERE Z325E LOT NUMBER 84 (A53084)
2025 JOHN DEERE...
2018 UTILITY VS2RA 53FT REEFER TRAILER (A56129)
2018 UTILITY VS2RA...
2021 KENWORTH T270 (A55745)
2021 KENWORTH T270...
JOHN DEERE 5075E (A53084)
JOHN DEERE 5075E...
FAE UML/SSL 150 VT QUICK ATTACH HYD MULCHING HEAD (A51406)
FAE UML/SSL 150 VT...
