My Homestead in the making.....
   / My Homestead in the making..... #31
Try hooking one root at a time and giving a bit of a pull so the stump is being twisted in a circle and watch to see where the ground moves. Then go dig out that root then try the same thing again when the stump starts moving a bit just keep wiggling it try from different angles and soon it will pop out. Straight on approach works better with big machines.
   / My Homestead in the making..... #32
I would try this first ^^
Another idea is to make an A frame out of heavy pipe, hook a chain over the elevated frame, and pull horizontally and the A frame will give leverage and change the horizontal pull to more of a vertical vector.
Tried this just now, nope.....It didn't budge. Tried from two angles, I'm going to go back out after lunch and try again from around the back. If it doesn't work, not sure what I will do. Might just dig deeper around it to loose some more soil and hope the weight plus me pulling at it will break it loose.....Wish me luck, because this stump is whooping my azz!
   / My Homestead in the making..... #34
The trick is don't saw the tree off to start with. Dig around the base like you have, cutting as many roots as possible, then reach as high up the truck as you can with the front end loader and push the tree in the direction you want it to go. This uses the weight of the tree as leverage on the stump.
LOT less work.
   / My Homestead in the making..... #35
I wish someone could explain to me WHY about 1/2 the time I post a reply, this software double posts it.......this the ONLY website this happens.
   / My Homestead in the making..... #36
They had it fixed for a few weeks, but is is doing it again.
I just delete the second one, when it happens to me.
   / My Homestead in the making..... #37
Like I said black powder or tnt.
Joking with you
   / My Homestead in the making..... #38
Always have patience and dig out as much as possible then just like a miracle they all of a sudden come loose.
The roots under those type of sumps are holding plenty of dirt I always dig under the stump as far as possible when they are very large for the size of my machine.
WELL WELL WELL!!!!!! Success!!!!!
I got the darn thing to break loose, learned a few things in the process. Next stumps will be drilled soaked with some flammable agent and then set fire too and left to roast for 48 hours. Then I will dig at them and hope to break them apart and pull out in pieces.
Got it flipped over and working on knocking the dirt off the bottom as best as I could.
Picture of it in the front next to the rest of my logs that I am figuring out where to put them.
Happy kids now that the trampoline is available again to be used.
   / My Homestead in the making..... #40
You have the benefit of having lots of projects that require seat time on the tractor. I finally got my road dialed in so well, it takes very little maintenance. I am kind of disappointed in my reduced seat time.
2016 Ford Explorer AWD SUV (A55853)
2016 Ford Explorer...
2020 Ford F-150 Crew Cab Pickup Truck (A53422)
2020 Ford F-150...
2001 INTERNATIONAL 2574 6X4 DUMP TRUCK (A51406)
2001 INTERNATIONAL...
2021 Kubota RTV-X1140RL-A (A47384)
2021 Kubota...
2012 Chevrolet Silverado 2500HD Enclosed Service Truck (A55788)
2012 Chevrolet...
(6) ROLLS OF MISC LINOLEUM (A54757)
(6) ROLLS OF MISC...
