My Grapple Project (part 1)
   / My Grapple Project (part 1) #71
Very nice Bill !!!!
Very good write up, detailed pictures and simple acurate discription.
Three grapple teeth up is what I give it /forums/images/graemlins/cool.gif /forums/images/graemlins/grin.gif /forums/images/graemlins/grin.gif
   / My Grapple Project (part 1) #72
Very good job.
One more project like that and you have paid for your welder. Then you will justify a plasma cutter, then horizontal bandsaw, ect. ect.
My wife is usually understanding about tool purchases because she sees them getting used and making our work easier. She was understandingly upset when I accidentally left my auto darkening welding helmet uncovered in the rain this last week. That was a big mistake. It’s one thing to buy a top notch tool once but another to not take care of it and have to spend that money again. Actually I think I’m more upset than her. It was hard going back to my old welding helmet again.
Eric
Don,
You fellow tbn'ers just don't miss a trick. I started this project with a 513 loader on the tractor. Friday morning as the paint on the grapple was drying, my dealer brings me a 723 loader to install. It was rather neat the way the photos turned out and I was wondering if anyone would notice, you did. BTW, I just wasn't satisfied with the performance of the 523 loader /forums/images/graemlins/frown.gif. That's a story for another post.
Bill
   / My Grapple Project (part 1) #74
Bill some of these guys are so observant that they will tell you when your next oil change is due. /forums/images/graemlins/wink.gif
Thanks for the kind comments Steven. It's always nice to know that your work doesn't go unnoticed /forums/images/graemlins/wink.gif.
Bill
Boy, I caught it from the hydraulic police on one project /forums/images/graemlins/blush.gif. I corrected that on this project /forums/images/graemlins/laugh.gif and now the loader police are after me /forums/images/graemlins/shocked.gif. I give up /forums/images/graemlins/grin.gif.
Bill
Eric,
My wife is the same way. I usually have no problems buying anything as long as the cost will justify itself. I've been working with all kinds of tools for nearly 40 years and one thing that I always remember to do when closing shop for the evening is accounting for the tools I used that day. It's a shame about your AD helmet. Did you try to dry it out??? Sometimes a hair dryer works wonders on circuit boards. It worked on my coffee soaked garage door opener /forums/images/graemlins/blush.gif.
Bill
   / My Grapple Project (part 1) #78
Eric I have a friend in the dock business and he lost his helmetafter 3hours on the first job it was on in18 feet of water. 7and a half hours later when he was ready to get wet he retrieved it. That was a year ago and hes still using it. Hope yours dries outit would help to change batteries after that to.
   / My Grapple Project (part 1) #79
Bill, I saw your numbers (thanks) and have spent a little time with them. I was trying to see what placements would give you a 90 degree or vertical opening. When you switched from the 90 degree arms to the boomerang style, it threw my model off and I don't have all the numbers I need. I have almost reverse computed the rest of your numbers. So, here is roughly what it would take to go vertical.
The front cylinder rod pin would have to be moved forward approximately 5 inches to give you a C-D dimension of 18" or so. Looks doable, hard to tell (except that those c-clamps seem to missing now /forums/images/graemlins/grin.gif).
The rear cylinder pin would have to about 4" behind and about 6" above the grapple arm pivots.
As for crushing cars, I understand that. I was thinking since your loader can probably lift 2,000 lbs+, it would be nice if you could hold something clamped vertically as heavy as you can lift. I looks like when your grapple is open 4" you still have about 1100 lbs of force, and around 550 lbs at 2". So I guess this plenty. You probably won't run across a 1000 lb rock or piece of steel that thin that needs lifting vertically, so it should be fine.
Anyway, playing with the numbers has been quite enlightening.
Nice project! I hope I make it into a grapple someday.
2013 Godwin Dri-Prime CD103M Towable Trash Pump (A59228)
2013 Godwin...
NEW HOLLAND 706 30 INCH 3PT DIRT SCOOP (A57024)
NEW HOLLAND 706 30...
UNUSED FUTURE 12" HYD AUGER (A52706)
UNUSED FUTURE 12"...
Kubota B21 TLB (A60462)
Kubota B21 TLB...
2019 Ford F-350 (A55973)
2019 Ford F-350...
2018 FREIGHTLINER CASCADIA TANDEM AXLE SLEEPER (A59905)
2018 FREIGHTLINER...
