My Front Gate Project
/ My Front Gate Project
Mine works fantastic, it even works with the Kawasaki Mule. I have it resting on a cinder block so nobody accidentally runs it over.
/ My Front Gate Project #82
Wait until one of the goats picks up a steel can and learns to walk out the gate......:goat:
/ My Front Gate Project #83
Before deciding on which opener to buy, I did a bunch of online searches to read as many reviews as I could, and watched more Youtube videos then I can remember. What's funny is that I never heard of the GTO opener. It never came up in any of my searches.
I think they bought Mighty Mule but might be mistaken. The GTO version like I have is much faster and is definitely heavier and better built. My best friend has the mighty mule setup on dual gates. Takes much longer to open but they still work well. The unit I have is more like entry level commercial verses residential grade.
/ My Front Gate Project #84
Took the gate cylinders apart this weekend. There was more than a cup of water in both of them. Cleaned out the weep holes, greased and put back together. My son also leveled one of the gates. Gates now open a lot faster. I hope they don't freeze but will have to wait for a few days to check. So guys remember to check the weep holes on everything this winter. I am lucky it didn't crack the plastic cases.
/ My Front Gate Project #86
i have ours buried about 1 foot underground just off the road, which is how the instructions said ot install it. It works perfectly. It won't pick up a bicycle but it will pickup anything golf cart size or larger.
/ My Front Gate Project #87
Interesting that you used black ink outside. I'm not sure it will hold up. Sun exposure tends to bleach color out of dyes, so it will depend on what it is made of. If it is full carbon black, then it should hold up fine, but if it is made from ink dyes then it will probably bleach out. It takes inorganic pigments to hold up outdoors (which carbon black would be). That is why you use paint pens for making outdoor signs and not sharpies as the sharpies fade in the sun very fast. Titanium dioxide is the most common inorganic pigment (TiO2) as it is white, so gets blended with a lot of things, especially in paints. A lot of metal oxides are used for these - Cobalt, Nickel, Iron, etc and the heavy metals in the old days Lead (thus the name "lead paint") and mercury, etc. but those are pretty well banned due to toxicity. The heavy metal pigments were super stable which is why they were used for so long, but as people became more aware of the toxicity concerns, that changed.
/ My Front Gate Project #88
His link said the ink is non-fading 100% carbon pigmented, so he should be fine.
/ My Front Gate Project #92
My mighty mule looks like a hydraulic cylinder on the outside, but it's just a tube over the screw. Ice had mine - definitely slow - for about 8 years; I replaced the motor with something off of eBay for about $50 last year.
I'm interested in this thread because I'm replacing my outer fence, going from 5' to about 7' and will be redoing our gate as well - moving it and going from a single ?10' to something like two 7' gates, custom design (... I need to find a crafter, my welding skills are not for public view!). Obviously I'll be replacing the opener as well.
Thanks for the link. For me, I decided that I did not want a hydraulic cylinder type of opener. Once I learned about the screw type openers, I felt that was a much better design for the long term. Only time will tell if I made the right choice.
I wasn't aware of all that. I was very pleased with how the black ink worked on my cement kitchen counter tops, so that's all I was hoping for. Hopefully I got lucky and bought something that will last. If not, I'll just do it again with something better. So far, it still looks fantastic without any sign of fading, but I'm sure that Summer will be the big test on fading.
Today is day ten of having Covid and the first day that I'm really starting to feel that it's coming to an end. It's never gotten really bad, just a lot of fatigue and random symptoms that come and go. sometimes they last all day, other days it's on and off again a during the day.
/ My Front Gate Project #94
We will keep you and and your wife in our prayers for a speedy recovery Eddie.
/ My Front Gate Project #95
Ford850 looked up your ink a few posts back and says it is non-fade carbon black, so you should be good to go. But something to make sure of in the future for any similar tasks.:thumbsup:
2016 Freightliner 108SD Truck (A64194)
2016 Freightliner...
(INOP)1989 NISSAN D21 EXTENDED CAB TRUCK (A64280)
(INOP)1989 NISSAN...
2006 Chevrolet TrailBlazer SUV (A66738)
2006 Chevrolet...
2007 Kubota RTV-X900 4x4 Diesel Utility Cart (A66734)
2007 Kubota...
2013 HAULMARK ENCLOSED UTILITY TRAILER (A67714)
2013 HAULMARK...
2006 PETERBILT 379 TRI-AXLE (INOPERABLE) (A67714)
2006 PETERBILT 379...
