My first Bolens
   / My first Bolens #1
pgcg4life
Bolens H14
I'm about to purchase an early 70's H14 that doesn't like to start. After some coaxing with starter fluid it will finally fire up. Once it is warmed up and has run for a bit it'll start right back up. Does anyone have any suggestions as to what may be the cause of these hard starts? Appreciate any help, thanks.
   / My first Bolens #2
I ran into the same problem years ago with a push mower. The problem was the gasoline was left over from the year before, put fresh fuel into it, no more hard starting!.
   / My first Bolens #3
Assuming the obvious things have been checked like fuel, spark plug, fuel line obstruction, and air cleaner, the most common reason for small engine starting issues is fuel not being drawn through the carburetor.
If you prime the engine with a small amount of fuel, and it starts right away, you have fuel delivery issues.
These engines rely totally on suction, for fuel flow. If the suction is not sufficient, it will not start.
This problem can be caused by lack of compression, or the choke not closing all the way.
The choke causes all the suction to be used to start the fuel flow. Check to see that it is adjusted to fully close, when the lever is in the choke position.
I Have owned a 1964 Bolens 600, for 30 years. I have modified it in to a 10 hp with hydraulics. It is mostly retired now, but it is a great little tractor. :thumbsup:
2005 WhisperWatt DCA-70SSJU2 70kVA Towable Diesel Generator (A52377)
2005 WhisperWatt...
JOHN DEERE 648R LOT NUMBER 105 (A53084)
JOHN DEERE 648R...
2013 John Deere 824K Wheel Loader (A55218)
2013 John Deere...
1840 (A51248)
1840 (A51248)
2013 FORD F-150 XL SINGLE CAB TRUCK (A51406)
2013 FORD F-150 XL...
2019 MACK PINNACLE P164T DAYCAB ROAD TRACTOR (A51406)
2019 MACK PINNACLE...
