My First Attempt at a Dump Trailer
   / My First Attempt at a Dump Trailer
Mike, I have figured already on having a 12" hangover past the hinge. That puts my length from the front to the fulcrum at 13'. I will have to verify that I have this clearance but I think I will be ok.
Meburdick, I understand what you are saying. My goal on this was because the initial estimate on this will have a significant tongue weight already. I will have a 4' front wall, a 10K winch (100#), the battery, the hydraulic pump, plus the dump bed frame. This is without anything loaded in it.
   / My First Attempt at a Dump Trailer #12
When you design it out, you can move the axles slightly forward if you know you will have "extra" weight up front to carry and want to put a larger percentage of them on the axles. That's not an issue.
I was only warning that you don't want to end up planning, say, a 7k trailer that will have only 400lbs of tongue weight. As long as you're certain to keep the percentages in line with 10%-15% of total weight being on the tongue, you'll be safe and it will tow nice.
Bobcat T590 (A53317)
Grove 4x4 Rough Terrain Hydraulic Crane (A55851)
Grove 4x4 Rough...
UNVERFERTH 330 8 AND 1/2 INCH EXTENSION STUB TUBE WELDMENT FOR FRAME (A55315)
UNVERFERTH 330 8...
PALLET OF 15 4X8 GROUND PROTECTION MATS (A58214)
PALLET OF 15 4X8...
HYDRAULIC THUMB FOR MINI EXCAVATOR (A58214)
HYDRAULIC THUMB...
More info coming soon! (A56858)
More info coming...
