My Ferguson Continental 135 engine cant find where to hook up the oil gauge line
   / My Ferguson Continental 135 engine cant find where to hook up the oil gauge line #1
Knifer
Winter Haven
Massey,JD 2010, International W6. '42 case
any Ideas where the oil port is?
   / My Ferguson Continental 135 engine cant find where to hook up the oil gauge line #2
I happen to have a picture I took while working on mine.
The oil gauge line connection point is located just to the right of your battery negative post connection point to the frame on the right side of the tractor. Just to the left of the oil filter.
You should use a line wrench when loosening or tightening it. I would put a bit of teflon tape on it upon final assembly. When you hookup to the gauge you will need to bleed the line at the gauge while engine is running till you see oil comming from the line then tighten securely. If you don't. Your gauge will either not work right or be inaccurate. -robert
thaanks
2018 Regal 29OBX 29ft Yacht with 34ft Trailer (A51694)
2018 Regal 29OBX...
John Deere GR72B 72in Dual Cylinder Grapple Bucket Skid Steer Attachment (A51691)
John Deere GR72B...
Year: 2008 Make: Toyota Model: Tundra Vehicle Type: Pickup Truck Mileage: Plate: Body Type: 4 Door (A51692)
Year: 2008 Make...
2017 Case SV185 Compact Wheel Loader Skid Steer (A51691)
2017 Case SV185...
2024 KMC 7406 LOT NUMBER 11 (A53084)
2024 KMC 7406 LOT...
2017 Ford Explorer AWD SUV (A51694)
2017 Ford Explorer...
